Username Post: Engine light on.. fast idle.. no auto shift        (Topic#358396)
Lostangyl
Reg: 10-10-19
10-10-19 10:29 AM - Post#2777561
Hey guys.. so 95 g20 van 5.7.. yesterday started van.. engine light came on ... Idle seemed fast.. no power in OD.. shifted manually to 1st and no problem.. won't shift by itself. Have to shift manually.. even then seems to only have 2nd and drive.. over drive will not ingage.. and in first gear shift manually to 2nd.. no shift.. any idea?
10-10-19 01:49 PM - Post#2777582
    In response to Lostangyl
Get it scanned post back with the code.
65_Impala
Reg: 12-29-02
10-10-19 02:40 PM - Post#2777584
Get the codes.
The 4L60e will only have manual 2nd and 3rd gear when it loses power or the PCM quits controlling the solenoids. Both shift solenoids off puts the transmission in 3rd gear and it has circuits which over-ride the solenoids and force manual 2nd when you put the gear selector in 1st or 2nd gear.
So, check fuses and the wiring.
Lostangyl
Reg: 10-10-19
10-10-19 08:00 PM - Post#2777611
    In response to 65_Impala
So pulled POS battery cable and.. reset.. so far problem solved.. limp mode.. question is why? Neg cable was loose yesterday.. but tighten it.. maybe bad ground?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
10-11-19 03:52 AM - Post#2777630
Had a 95 Tahoe a couple months back doing the exact same thing. Ignition switch (electrical part) was the problem.
Lostangyl
Reg: 10-10-19
10-11-19 09:28 PM - Post#2777704
    In response to junkman104
So far so good.. drove all day today.. hoping it was just cause ground was loose
Execution time: 0.093 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:41 AM
