Username Post: harmonic balancer        (Topic#358378)
virg809
Loc: ks
Reg: 11-08-15
10-09-19 09:01 AM - Post#2777462
1960 283 the balancer was coming off so I drilled the crank and used a bolt....back together and it squeals a little bit.....should I replace it and where is a good place to get one thank you
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
10-09-19 11:26 PM - Post#2777525
    In response to virg809
Sounds more like you have a pulley/drive belt issue than a dampener issue. Rough up the "V" of the pulleys with some course sand paper, and use a bar of soap on the belt surfaces; see if that does't stop the squeal. If it does, it probably won't last very long, and you may need to replace the belts with new ones. Also, make sure the tension on the belts is tight enough, so the belts don't slip, and cause a squeal. JMO.
I am Butch/56sedandelivery.
virg809
Loc: ks
Reg: 11-08-15
10-11-19 05:01 AM - Post#2777636
took the belt off still doing it so must be balancer
Hobart
Hobart
Loc: Chicago, IL USA
Reg: 11-18-02
10-11-19 06:42 PM - Post#2777695
Try to ascertain if the outer ring of the balancer has slipped. Did the hub of the balancer seem loose on the crank, or could it have just been the ring loose on the hub?
Bill
Chicago Gearheads Car Club / Lynch Mob Racing
'59 Bel Air 2dr sedan
'68 Chevy II Nova
'72 Eldorado ragtop
'80 Z28
virg809
Loc: ks
Reg: 11-08-15
10-12-19 05:17 AM - Post#2777713
    In response to Hobart
when I got to a car show there was a noise and I found out the whole balancer was coming off, found out that yr 283 did not have a bolt in it. so I drilled the crank,tapped it and put a bolt in, now it makes a little squeal and I don't know if it is wobbling or not, I suspect the center of the balancer is wore down, the make a kit to go on it but I am thinking of just replacing the whole thing , the key looked ok by the way
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
10-12-19 05:31 AM - Post#2777716
If the keyway is good there is no way the centre of the balancer is moving / slipping but it could wobble if the clearance fit is loose. The outer ring could move though. This can be checked by setting #1 cylinder to tdc and see where the timimg mark is.
Are you sure its not belt slippage?
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
Edited by Original58 on 10-12-19 05:33 AM. Reason for edit: No reason given.
Execution time: 0.16 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:56 PM
