Username Post: Bath tub safety handle        (Topic#358376)
2blu52
2blu52
Reg: 03-12-02
10-09-19 07:53 AM - Post#2777460
Since it is my belief that the greatest minds ever ,frequent this site I have an unusual question. I recently purchased a safety handle for the bathtub. It is in addition to one I have had for several years. (old age catching up)Both are held in place with vacuum cups. The new one hung in place for about two weeks and then started coming loose and falling into the tub. The new one is hung on an outside wall, and temperatures have been changing up and down for about the same time as the handle started coming loose The outside wall is a 2x8 insulated wall. Could the changes in temperature be causing the handle to come loose?
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
monty56
monty56
Reg: 04-26-04
10-09-19 10:44 AM - Post#2777479
    In response to 2blu52
Those handles rely on vacuum and since no surface is completely smooth the small marks on the wall will let air in eventually. althoug temp changes could have an effect as well. Just set up a schedule to refasten weekly or?
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
10-09-19 10:52 AM - Post#2777480
Harbor Freight items? I ask because I have 4 of them, and they occasionally come loose, and sometimes fall off on their own; other times they come off in my hand. For those reasons, I always check them before actually "using them". I think they're just typical, Chinese made/copied, merchandise. I clean the wall, and the suction cups, use a little soap film on them, and stick them to the enclosure; they seem to stay on longer that way. These things were originally copied from the ones used to handle/carry sheet glass, but those go on/off, and are't left in place for very long. You'd think they'd make tub/shower enclosures with attached hand holds. I am Butch/56sedandelivery.
2blu52
2blu52
Reg: 03-12-02
10-09-19 02:21 PM - Post#2777490
Neither are from Harbor freight but who knows what quality they are. I will try the soap film. Wetting it does not do the job.
THOMAS JEFFERSON
Mick53
Mick53
Loc: Northern Indiana
Reg: 04-02-16
10-10-19 05:51 PM - Post#2777608
clean the wall and try a very thin coat of silicon.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
10-11-19 07:36 AM - Post#2777650
I can't image relying on suction cup safety handles. Sounds like an oxymoron item.
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
2blu52
2blu52
Reg: 03-12-02
10-11-19 09:18 AM - Post#2777661
    In response to tommy49
You have to be ware of what you have for sure!
THOMAS JEFFERSON
tommy49
tommy49
Reg: 09-28-12
10-11-19 10:02 AM - Post#2777667
kind of hard when you're on your way down!
Tommy
55Redneck
Loc: Hedley B.C. Canada eh!
Reg: 06-24-00
10-11-19 11:21 AM - Post#2777670
Blu, if you are using this as a grab handle I would be very very careful. Suction cup grab bar sounds to me like a broken hip or tail bone waiting to happen. In my 3 decades of installing tile, if the customer wants a grab handle installed in their bath tub enclosure there is usually a piece of 2x6 bracing screwed in between the wall studs so when the grab bar is installed after the tile is done there is something solid to anchor it to. I'll say it again, be very careful when grabbing that suction cup dealy my friend, we wouldn't want to hear about you hurting yourself.
In memory of Mike McVeigh, the Mad Springwhacker.
2blu52
2blu52
Reg: 03-12-02
10-11-19 03:08 PM - Post#2777685
    In response to 55Redneck
Caution is the word. Double check going in and coming out.
THOMAS JEFFERSON
Senior Moderator
10-12-19 04:25 AM - Post#2777714
I think what Mark is suggesting is that even if the suction cup holds, the tile may not!
tommy49
tommy49
Reg: 09-28-12
10-12-19 04:59 AM - Post#2777717
Suction safety handle = tie wrap rappelling carabiner.
Tommy
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
10-13-19 09:31 AM - Post#2777782
I install grab bars and use these bolts:
https://www.amazon.com/TOGGLER-SNAPTOGGLE-Zi nc-Pla...
82 Monte Carlo SC, 355 w/Vortec heads, roller rockers, 625 Demon Carb, TRUE DUALS.
2009 Sub.5.3L LTZ 30 Gallons of gas @ $2.28/gal. bla bla bla.
JasonZ
Loc: San Antonio Texas
Reg: 02-21-03
10-29-19 08:36 PM - Post#2779109
    In response to black95jimmy
Never use those suction cups! Always put in a solid bar in that can hold weight. You’re 86 not 68. I don’t want to hear that you fall down and go boom. A broken hip or a fall at your age is a death sentence. Doing cpr, if you where to stop breathing or Agonal all after a fall, to bring you back will break every rib on your body.
Don't go BROKE trying to look RICH. Act your WAGE!!
2blu52
2blu52
Reg: 03-12-02
10-30-19 04:16 AM - Post#2779116
    In response to JasonZ
Thanks for all the replies, going to look into something more solid!!
THOMAS JEFFERSON
Execution time: 0.117 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:58 PM
