Username Post: How to adjust toe and camber        (Topic#358364)
LSS1333
Reg: 05-13-15
10-08-19 09:49 AM - Post#2777372
Just finished my drum to disc conversion. Now both front tires look to be out of alignment. The drivers isn't too bad, but my passenger tire looks to have a pretty bad "toe out and negative camber."
Is there anyway to adjust this at home, before taking it in for alignment?
Edited by LSS1333 on 10-08-19 09:50 AM. Reason for edit: No reason given.
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
10-09-19 04:22 AM - Post#2777441
    In response to LSS1333
https://www.google.com/search?q=HOW+TO+ADJUS T+TOE+...
omarine
omarine
Loc: Orlando - Tampa, FL
Reg: 06-29-15
10-09-19 06:30 AM - Post#2777453
it can be done at home, but it can be finicky. Camber and caster is done with the shims - not all "alignment shop techs" seem to understand this.
the book shows how to do it, and you can get one of those king pin, caster camber gauges on ebay.
youtube videos make toe look easy, but I usually find a way to screw it up
just went through this myself.
cheers
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
10-09-19 09:34 AM - Post#2777466
I've done conversions on these cars in my shop, converting to disc brakes should not radically change toe or camber, what exactly was done in the conversion?
Execution time: 0.102 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:24 AM
