Username Post: 05 cavalier soaked        (Topic#358349)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-07-19 03:39 PM - Post#2777297
Hi, MY 05 CAVALIER 2 dr gets a soaked driver floor when it rains and I wonder if there is a common problem or if this is only on my car. I cleaned all the rubber door seals and channel runs and any debri, had a cracked windshield replaced with the new glass seal, and still the water gets in. The car is parked while this occurs. Is it in the cowl vent area? Any ideas?
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-17-19 06:42 PM - Post#2778156
    In response to 995jim
I would remove the cowl panel and run a hose in the area, have someone look to see if it drips inside.
It could be windshield seal.
Inspect it well around the sides and bottom.
Make sure there are no gaps between the cowl and the windshield.
What is the rust factor? If rust is excessive I would be checking the firewall at the seam about half way down for rot
Old School GM fan FOREVER
Execution time: 0.084 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:29 AM
