Username Post: whats sealer ?        (Topic#358347)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-07-19 03:27 PM - Post#2777295
hi, Is epoxy primer considered a sealer or is there a specific product sprayed on that is called a sealer and what point is the sealer applied?
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
10-08-19 04:54 PM - Post#2777412
    In response to 995jim
Sealer is essentially a thinner version of primer. It’s applied right before the base coat or color is applied. if you have a car that is fully primed or has no primer spots at all (as in a repaint where no body work was needed) and if the primer or existing color coat hasn’t been sanded through, you don’t need to use sealer if prepped with a fine enough sandpaper. My El Camino needed no sealer because it was fully primed and I sanded the primer with 400 grit to get rid of the orange peel and followed that with 600 grit.
1957 Cameo Carrier
lone star
Reg: 08-24-08
10-11-19 04:01 AM - Post#2777635
epoxy primer, when reduced can be used as a sealer before basecoat. all sealer does is make the surface uniform in color to prevent bleed thru from feathered edges of filler/primer/bare metal. it helps with coverage of the basecoat, especially in metallic paint jobs.
Execution time: 0.148 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:01 AM
