Username Post: whats sealer ?        (Topic#358347)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
10-07-19 04:27 PM - Post#2777295
hi, Is epoxy primer considered a sealer or is there a specific product sprayed on that is called a sealer and what point is the sealer applied?
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
Site Ambassador
10-08-19 05:54 PM - Post#2777412
    In response to 995jim
Sealer is essentially a thinner version of primer. It’s applied right before the base coat or color is applied. if you have a car that is fully primed or has no primer spots at all (as in a repaint where no body work was needed) and if the primer or existing color coat hasn’t been sanded through, you don’t need to use sealer if prepped with a fine enough sandpaper. My El Camino needed no sealer because it was fully primed and I sanded the primer with 400 grit to get rid of the orange peel and followed that with 600 grit.
1957 Cameo Carrier
lone star
Reg: 08-24-08
10-11-19 05:01 AM - Post#2777635
epoxy primer, when reduced can be used as a sealer before basecoat. all sealer does is make the surface uniform in color to prevent bleed thru from feathered edges of filler/primer/bare metal. it helps with coverage of the basecoat, especially in metallic paint jobs.
Execution time: 0.078 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:27 AM
