Username Post: Shock Wave Shocks        (Topic#358318)
Nicksd
Reg: 09-02-09
10-05-19 08:11 AM - Post#2777128
Has anyone had success with the using the Shock Wave Shocks on there front end to cushion the ride. I have a 1955 chevy conv. and it rides rough. I'm in the process now of putting new leaf springs on it I sure hope this works. The ones I took of are no good.
redlinetoys
redlinetoys
Reg: 04-17-04
10-06-19 03:18 PM - Post#2777196
    In response to Nicksd
New leaf springs should help the back. I like KYB gas shocks, but they are a little stiffer and work best if you have a shock bar to keep the shocks from going through the floor pan.
Regarding the shockwaves on the front, I do have them. I have them on the least firm setting and they are still a bit firm unless you air them up to at least 70psi or so. Anything less and they bounce around too much. Airing them up above 90psi or so causes a firmer than desired ride.
If your car is at stock ride height, I think you would be best staying with original coils and a good set of shocks.
Bob
RedlineToys
http://www.youtube.com/watch?v=GslLKzhPth8
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
10-10-19 08:04 AM - Post#2777552
What do you have up front now that rides poorly
Nicksd
Reg: 09-02-09
10-12-19 10:50 AM - Post#2777734
    In response to Nick P
2" drop spindles and 2" lowering springs.
Execution time: 0.296 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:25 PM
