Username Post: PS,ALT belt issues        (Topic#358303)
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
10-03-19 02:48 PM - Post#2777015
I am trying to run an alternator on the passenger side in the first pulley groove, why doesn't the lower radiator hose clear the belt?
Power steering pump in the second groove on driver side.
What lower radiator hose do I need, rad is in 6 cyl. Position.
I have been running the alt in #2 groove and the ps in #3 just crank and ps pump.
Basically the #1 groove running anything on the passenger side will not work, belt will not clear the lower radiator hose.
Have I fitted the lower hose incorrectly?
Do I need one of thos flexible type hoses to do this?
Or is this impossible and I need to mount the alt way up high where you question if the hood will close?
What am I doing wrong here?
What has brought this on is belt slippage on the water pump from current configuration.
VC56S 2 door Sedan, 40 Years
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
10-04-19 11:54 AM - Post#2777081
    In response to Bad56Sedan
I bought 7 different pulleys trying to make this work, now it looks like it is the configuration on the lower radiator hose.
If ya look close at what the various repop boutiques that are selling these hoses they are all a bit different.
This will be a timely and costly episode if this all mattered on the manufacturer of the lower radiator hose.
We will see, I have ordered a different lower rad hose from one of the popular repop boutiques. Here's the issue, the belt hits the lower rad hose, just because the way the hose is made?
Attachment: image.jpg (182.37 KB) 12 View(s)
10-05-19 07:01 AM - Post#2777121
There was never a V-8 tri-5 manufactured with a radiator in the 6 cyl position, and passenger side alternator or a belt driven power steering pump. There is way too many combinations for a manufacturer to make a hose specifically for yours. You have to get a ready made hose with the right bends and cut to fit.
P.S. Aluminum pulleys are know to slip easily.
Edited by acardon on 10-05-19 07:02 AM. Reason for edit: No reason given.
10-06-19 11:10 AM - Post#2777181
cant see the problem good in the pic. i would probly move the alternator. or maybe use a peice of metal tubing where it rubs and flaten it a bit .
Jalapeno
Member #252
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
10-06-19 06:47 PM - Post#2777211
What is the location of the driver side PS pump? If you mount it low down, below the height of the exhaust, you can mount an alt above it on the driver side. This is how GM did it on short water pumps, long water pumps, etc.
Jalapeno
WagonCrazy
WagonCrazy
Reg: 06-07-05
10-07-19 08:56 AM - Post#2777257
    In response to Jalapeno
keep it simple...
pull the lower hose out and go down to your local NAPA and ask them if you can look thru all the hoses they have hung up and find one configured similar, but with more space for that 90 degree turn that seems to be where the belt rubs.
that's how ive done the last 2 tri fives I've modified...just do it visually. forget about using specific recommended tri 5 hoses. You need a smidge more spacing at that 90 degree curve coming out of the water pump.
FiftiesMan
FiftiesMan
Loc: Washington, USA
Reg: 06-07-06
10-08-19 01:38 PM - Post#2777389
I'm with WagonCrazy to just keeping it simple. But from the looks of the picture you provided it seems like you ran out of length on the hose and have it cocked too far forward off the water pump, which is allowing it contact the belt at the 90* bend. If you have enough length to it then just re-position the hose on the water pump back towards the fuel pump/block which should then clear the belt at the 90* bend. But if you don't have the length to do that and allow it to get hooked up to the radiator, then maybe the new hose you just ordered will work out better.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
10-08-19 03:49 PM - Post#2777406
    In response to WagonCrazy
Several vendors sell a lower radiator hose designed to work with a V8 engine in the 6 cylinder position.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
10-10-19 08:56 PM - Post#2777615
New lower hose, finally it does clear
Belt in first crank groove
The cheaper generic hoses do not have the bends like the higher priced reproduction 5-6-7 hoses and I cut it too short
Finally, finally I got it!
Attachment: image.jpg (166.95 KB) 9 View(s)
Attachment: image.jpg (132.92 KB) 11 View(s)
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
02-05-20 03:49 PM - Post#2785962
After years of dealing with this issue,
Getting an acceptable amount of clearance trying to run an alternator on the passenger side, I realized I wanted more clearance, more pulleys? More brackets? Run set up the other way?
Power steering on driver side, I wanted more than just the alt. belt on 1/4 of the water pump pulley.
I was running power steering just on a triple crank pulley in the 3rd groove to the pump.
So the alt only ran through the first grove on the water pump.
Can all this and get the $1500 serpentine set up? Get the long water pump and work from there?
NO!
Make spacers and move the crank and water pump pulley out about 1/4" more!
It works, so;
Short water pump,
Alt on passenger side Marches adjustable bracket,
CCCI power steering bracket set up home made spacer for that,
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
02-05-20 03:51 PM - Post#2785963
Attachment: image.jpg (175.54 KB) 4 View(s)
Edited by Bad56Sedan on 02-05-20 03:52 PM. Reason for edit: No reason given.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
02-05-20 03:53 PM - Post#2785964
Attachment: image.jpg (188.54 KB) 6 View(s)
Execution time: 0.089 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:26 AM
