Username Post: 8.1 liter running rough then clears up        (Topic#358299)
ShovelayNut
ShovelayNut
Loc: Ellenboro, NC USA
Reg: 04-03-02
10-03-19 05:46 AM - Post#2776977
I have a 2001 8.1 that runs good most of the time but sometimes when starting cold it runs very rough and is real weak. If I turn it off and restart it will clear up and run smooth. Is this a common problem with this engine?
See the USA in your Shovelay
10-03-19 07:25 AM - Post#2776987
    In response to ShovelayNut
Any check engine lite?
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
10-03-19 02:34 PM - Post#2777023
Does this engine have an extra injector for start up?
10-03-19 02:58 PM - Post#2777026
    In response to Mel Foye
No, just pcm controlled injector enrichment.
10-04-19 08:22 AM - Post#2777073
Possibly a coolant temperature sensor problem.
If you could get a real time scanner on it, that would confirm, or else show what the real problem is.
ShovelayNut
ShovelayNut
Reg: 04-03-02
10-07-19 05:41 AM - Post#2777245
No check engine lights or extra injector but the temp sensor might be it. I went ahead and put two new O2 sensors in (before the cat) because one appeared to one be flaky. Haven't drove it yet. Will definitely check on the temp sensor. Thanks. By the way, while I was under there, I couldn't find any O2 sensors after the cats. Does this vehicle only have two sensors?
Edited by ShovelayNut on 10-07-19 05:46 AM. Reason for edit: No reason given.
Execution time: 0.084 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:21 AM
