Username Post: Weird LED turn signal issue...        (Topic#358294)
bluesfella
bluesfella
Loc: Tallahassee FL
10-02-19 05:26 PM - Post#2776944
I put LED tail light bulbs in my '55 - the (1157?) drop-in kind. They are nice and bright. But since the turn signals didn't flash at first, I put an LED flasher in, and thought I was good. But I've noticed a problem:
With the lights on, the turn signals work fine.
With the light off AND the brake lights on (I'm pushing the brake pedal down), the turn signals work fine.
With the lights off, and I'm NOT pushing the brake pedal, the turn signals flash BOTH sides. Either side will do the same thing, flashing both turn signals.
How the heck do I fix that so it will work as designed?
10-02-19 06:22 PM - Post#2776946
    In response to bluesfella
Do the dash turn indicators both flash also? Does the flasher have a ground wire and is it grounded good?
bluesfella
bluesfella
Loc: Tallahassee FL
10-02-19 08:10 PM - Post#2776957
    In response to acardon
No, the dash indicators show what the turn signals should be doing, only one blinking at a time.
The new flasher was a plug-in replacement. I didn't add any wires to it.
bluesfella
bluesfella
Loc: Tallahassee FL
10-03-19 05:54 AM - Post#2776979
AND, the weird thing is that the front turn signals operate as they should. They aren't LED though.
10-03-19 07:08 AM - Post#2776985
Check that the tail light housings are grounded good to the body (screws tight). What's the part # of the flasher?
bluesfella
bluesfella
Loc: Tallahassee FL
10-03-19 11:16 AM - Post#2777002
I bought THIS ONE from ebay (Johnnylawmotors).
Here's the stats:
Reference part number: JLM1817690
No-Load LED Tail Light Flasher for Painless Wiring Harness car 12v DC hot rods from Johnny Law Motors...
Body Material :: Plastic
Input Pin :: .250
Output Pin :: .250
of Pins :: 2
Bulbs :: Incandescent or LED
Socket Type :: OEM
Max Lamps :: 10 1156
Volts :: 11V- 15V Normal DC
Flash Speed :: 1.5 Sec or less for 1st Flash
Voltage Drop :: 800 mv at Max Load
Flasher Per Minute :: 60-120
Duty Cycle :: 35% -75%
Feature :: -
Feature :: Fits Factory Socket
Feature :: Plug and Play
498 chevy
498 chevy
Loc: hayward ca.
Reg: 09-28-07
10-03-19 01:25 PM - Post#2777007
Thanks for posting this problem. I've put led lights in my 4 dr but not the point of having juice to them. Very interested in why this happened.
niftyfive
Loc: Durango, Colorado
Reg: 02-07-05
10-06-19 08:36 PM - Post#2777229
    In response to 498 chevy
I would reinstall the original filament bulbs and ck their operation. The specs on that flasher say its good for incandescent or led. This will confirm or negate that you have a wiring or bulb contact issue.
NIFTYFIVE
Execution time: 0.058 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:23 AM
