Username Post: 86 fuel transfer issues        (Topic#358290)
J w judge
Reg: 10-02-19
10-02-19 12:06 PM - Post#2776924
Complex issue.
Renovating an 86
Silverado.
Had a modified vortec engine installed.
Got around 400hp. Wanted to keep the dual
Tanks. Guy couldn’t figure out the transfer
Switch. There are four wires to it
Can any one tell me where they Should come from?
Diagram would really help.
They tried to operate the dual electric pumps
Through that switch but it’s all bonkers. Neither pump
Will work unless you fully depress the switch on the tank.
It will then crank but
You have to hold
It down for the motor to run.
If
I can figure out how the original
Wires were thinking of a three position
Toggle switch to run the pumps.
These guys did a great job on the motor
But I drove it home cut it off and then all the above
Issues started. Might add too there’s a lot of heat in that switch. Thanks in advance.
Mad Professor
Reg: 12-30-08
10-02-19 10:11 PM - Post#2776960
    In response to J w judge
I have a wiring diagram but can't attach files?
How do you "enable attachments?
from what I see
pnk/wht to left tank, fuel level
pnk/blk to right tank, fuel level
pnk to bulkhead connector then inst panel
lt grn to fuel tank selector switch
dk grn to fuel tank selector switch
the greens via a connector and through a grommet, they run together.
62 Willys wagon
67 CJ5 Buick V6 w/OD
89 S10 baja package
Edited by Mad Professor on 10-02-19 10:31 PM. Reason for edit: No reason given.
J w judge
Reg: 10-02-19
10-03-19 11:15 AM - Post#2777001
    In response to Mad Professor
If smart phone might screen shoot it. Depends
On your circumstances. Dropped by Chevy
Dealer today. Printed off six sheets of wiring
Diagrams. Everything except what I need.
Unfortunate today test a lot of people in businesses
Are inept to help.
Then yo Lowes got help. Forget that. If you can’t
Find it yourself don’t go.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
10-03-19 04:22 PM - Post#2777030
J w judge
Reg: 10-02-19
10-04-19 03:35 AM - Post#2777047
Many thanks. You did good for me.
I can now get it back to the original wiring
Going to put the in-tank pumps in a
Nice Toggle right under the transfer
Switch.
Senior Chevytalk Moderator
10-05-19 05:16 AM - Post#2777117
Welcome to the site. Go here to download a full factory manual. http://forum.73-87chevytrucks.com/smforum/index.ph...
To run fuel pumps off the switch, use relays to activate power. Running switch power to the pumps is not ideal. Are you using fuel injection or carb?
I’m about to go through a similar mess. The left tank on mine reads way paste full. Never know when the tank goes empty until the engine starts to shutter. A quick switch flip and it comes back to life. I’m going replace both sending units by lifting the bed.
Execution time: 0.128 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:59 PM
