Username Post: Intake Manifold Gaskets        (Topic#358251)
apix17
Loc: San Francisco Area
Reg: 12-22-07
09-28-19 06:43 PM - Post#2776653
My 55 Belair with a pretty much stock 68 327 SB with a mild hydraulic cam, small valve heads and edlebrock performer series 4 barrel needs intake manifold gaskets due to oil leaks. My question is should I use the gaskets that block of the center port that I assume supplies heat to the carb. I have had some problem starting with engine hot which is pretty good after installing a spacer under carb. I live in Northern Ca. and currently have the heat riser wired open and no problems with cold engine drive ability. Appreciate your input.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
09-29-19 06:47 PM - Post#2776738
    In response to apix17
I would suggest Fel-Pro 1204 which have stainless steel block-off plates for the exhaust crossover.
I would also suggest using a ¼” bead of RTV on the ends instead of the cheesy rubber gaskets that come with all gasket sets for SBCs, they always squeeze out and cause leaks.
09-30-19 06:41 AM - Post#2776758
    In response to YOUNG57
Seconded.
apix17
Reg: 12-22-07
10-02-19 04:54 PM - Post#2776938
Thanks to you both for your input. I am going to go with blocking off the passage with the fel pro gaskets and seal the ends with RTV.
apix17
Reg: 12-22-07
11-01-19 11:28 AM - Post#2779311
One further question regarding the installation of the intake gaskets. I will go with the RTV on the ends but I would like to not use any type of gasket shellac on the intake gaskets themselves around any of the fuel or water ports. But of course I am concerned with leaks. In other words might I get some leaks if I install the side gaskets in dry. I would appreciate any opinions on this Thanks
11-01-19 12:17 PM - Post#2779315
I used a thin bead around both sides of the gaskets around the coolant ports, just a little insurance. Let it set overnight before filling the cooling system.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
11-02-19 05:41 AM - Post#2779360
Fel-Pro 1204 Performance intake manifold gaskets have Printoseal beads of special elastomers around the ports for extra sealing power.
No need for any other sealer around ports.
Execution time: 0.111 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:25 AM
