Username Post: Wanted: York Compressor Bracket for V-8        (Topic#358249)
kck71
Reg: 10-23-08
09-28-19 06:03 PM - Post#2776648
Looking for bracket to mount older square style York A/C compressor to small block 327 V-8.
JimKshortstep4x4
Chevytalk Moderator & "15th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
10-02-19 07:14 AM - Post#2776912
    In response to kck71
Do you happen to have a picture of the bracket?
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
10-02-19 03:25 PM - Post#2776934
what car/truck are you wanting to put it in?
I have one that I removed from a 68,C-10.
When originally made,they were for specific applications.
Mike.
kck71
Reg: 10-23-08
10-05-19 06:13 AM - Post#2777123
Unfortunately, no, I don't have a good picture. From what I can tell, the bracket has tensioning pulley on it.
kck71
Reg: 10-23-08
10-05-19 06:15 AM - Post#2777124
    In response to 100 CHEVY
I'm looking to put it on a 57 car that has a 327. It needs to mount on the passenger side of the engine as the original generator and PS pump combo is on the driver's side. Can you post or email a picture of your bracket?
100 CHEVY
100 CHEVY
Reg: 12-09-04
10-05-19 11:08 AM - Post#2777141
when I can find it again,I'll try it on my 57 and see if it will fit.
I think it will.
I don't remember an idler and the mounting base may be slotted for the adjustment.
I'll check this afternoon if I can.
Mike.
I did find it and put it on the 57 today.It fits fine.I have the idler for it as well as the upper brace to the intake.There's about 3/4" between the pump head and the battery.The ports point toward the firewall.The idler mounts on the drivers side of the water pump and intake.The pulleys I have mount on a 6-3/4" balancer.my engine is a 1975,350 and the mount hits the heater hose connection.Yours may be in a different location and it may not be a problem depending on the intake you're using.
I have the whole system from the 68 truck.all would work except the condenser-not sure about it and didn't check it for fit on the 57.
I can't post pics because I have photobucket and they won't let me.
If you want to send me your E-Mail thru private message,I'll try to send you the pictures.
Mike.
Edited by 100 CHEVY on 10-05-19 03:23 PM. Reason for edit: No reason given.
kck71
Reg: 10-23-08
10-05-19 06:14 PM - Post#2777162
PM Sent. Thanks.
Execution time: 0.093 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:18 PM
