Username Post: '66 Ignition switch replacement        (Topic#358222)
bnunley1966
Reg: 09-24-19
09-26-19 12:46 PM - Post#2776520
Have any of you replaced the ignition switch in a '66 Malibu before? Does the dash have to be removed to get to it?
Bellarry55
Bellarry55
Loc: Southwest Illinois (near ...
Reg: 12-31-02
10-01-19 08:16 PM - Post#2776893
    In response to bnunley1966
You might be able to replace it without removing the dash. I had my dash apart the last year but I think you can remove the nut, pull the switch out carefully by using the wire harness to get it down. Replace the switch on the harness and then use the harness itself to carefully work the switch back up to its proper location.
www.mrchevynut.com
Execution time: 0.091 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:57 PM
