Username Post: '59 Impala Gauges Restoration        (Topic#358208)
Los59
Los59
Loc: Phoenix, AZ
Reg: 11-14-10
09-25-19 03:03 PM - Post#2776440
I am in the process of restoring the factory gauges from my '59. Before I screw something up as far as the gearing, does anyone have a good reference when tackling this? Ive searched the forum but did not find what I was looking for. Im starting with the speedometer since its the largest, I have taken it apart and will be polishing the aluminum bezels and painting what is needed. I will also be restoring the plastic unless anyone knows of glass replacements.
Any help is appreciated as always.
1959 Impala Sport Coupe Factory 4-Spd
Russ
Russ
Loc: Sacramento, CA USA
Reg: 12-16-99
09-27-19 02:00 PM - Post#2776593
    In response to Los59
I'm pretty sure the plastic lens are available from Chevy suppliers.
I didn't dive into my gauges all those years ago (I would now thanks to YouTube), so I sent them to Williamson's Instruments in Arkansas. If i recall, he overhauled my speedo for $100 (20 years ago) and tested my temp gauge. He had an NOS odometer that he installed for $75.
Nice folks
Los59
Los59
Loc: Phoenix, AZ
Reg: 11-14-10
10-25-19 07:25 PM - Post#2778771
    In response to Russ
Thanks Russ, I figured out how the odometer dial functions after disassembly. I should be good. I have an extra set of gauges so I can experiment lens resto there since there isnt a glass option (safety reasons maybe?).
cahartley
Loc: Central Wisconsin
Reg: 01-16-14
10-26-19 08:57 PM - Post#2778843
I thought I had the odometer figured out too.
I was wrong.......
Good luck........you're going to need it.......
www.youtube.com/cahartley7
Los59
Los59
Loc: Phoenix, AZ
Reg: 11-14-10
10-27-19 03:56 AM - Post#2778849
    In response to cahartley
Thanks for the vote of confidence lol. Everything seems to be functioning as it should with the dial, so hopefully I did get it.
Can someone post pictures of the gauges while illuminated? I can’t find any reference images with stock gauges lit up at night. This would be very helpful if someone can share. Also, does anyone know of the correct fluorescent orange color for the needles? I bought some paints but none seem to have the same “pop” as the originals.
Thanks as always!
62sedan
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
10-27-19 08:21 AM - Post#2778870
I used Testors fluorescent orange modeling paint when I restored my gauges needles. I thinned it slightly to avoid any extra weight on the needles while applying a thin coating, and it worked well and matched extremely close to the original finish.
Chuck
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
11-26-19 12:07 AM - Post#2780968
Same here, I have several spares, can't get the odometer to work on any of them.
Larry
36 Dodge Street rod..........owned 27 years
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
11-26-19 12:09 AM - Post#2780969
I have several spare odometers, I haven't been able to get any of them to work.
Larry
johnperri
Reg: 03-05-17
12-14-19 07:48 AM - Post#2782126
    In response to wings59
I tried to repair two speedos and a gas gauge. After installing them, taking them out, fixing them again, taking them out, etc. it would have been cheaper to have a professional restore them.
I Roger Blanchard 2744 PARK MILLS RD ADAMSTOWN, MD 21710-9103
301-518-9699
He lists items on eBay. He charges $80 to repair a speedo and I think $20 for the gauges plus shipping. I sent and received them within a week. Installed them and they work. So if your time is worth anything then consider using Roger.
Execution time: 0.388 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:56 PM
