Username Post: Oil pressure light stays on        (Topic#358170)
70Impsla
Reg: 09-23-19
09-23-19 08:14 AM - Post#2776241
Hi to all,
I have a 1970 Chevy Caprice with a 350 engine.
I’m having issues with my oil light staying on after I start the engine. Oil level good, replaced sending unit by distributor and I don’t think it’s the oil pump. With engine running I turn on headlights and the light goes off. I replaced dash bulbs with led’s, polarity checked. Strangely enough when I hit either turn signal they stay lit and don’t flash. Also, brake warning light stays on.
Any suggestions? Please advise thank you!
09-23-19 08:26 AM - Post#2776243
    In response to 70Impsla
You have a bad ground on the instrument cluster. There probably should be a brass strap between the cluster and metal part of the dash board.
Execution time: 0.184 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:56 PM
