Username Post: 59 El Camino nearly finished, sunvisor tension        (Topic#358158)
stevelegel
stevelegel
Loc: Detroit MI
Reg: 09-27-09
09-22-19 07:04 PM - Post#2776190
The 59 sun visors rely on the screw tension to hold them up. There is no bushing to help them grip. If you tighten the screw enough you are likely to snap the zinc casting. Catalogs do not sell a workable plastic insert. So I made one. I used the pop off, soft plastic protection seal from a water bottle (not a the screw on bottle cap). I cut the side wall and trimmed it to wrap tightly around the shaft of the visor arm. It does not go deep into the well past where the screw locks the arm, but rather only a 1/4 inch or so around the arm outside of the screw, but still inside the visor. Works great. Mind you I tried several plastic bottles to find one with adequate thickness and pliability.
ragtp66
Reg: 12-09-07
09-23-19 08:56 PM - Post#2776306
    In response to stevelegel
Maybe these from a chevelle? https://www.summitracing.com/parts/oer-k624?seid=s ...
Toys:
1987 Sea Ray Pachanga 22
stevelegel
stevelegel
Loc: Detroit MI
Reg: 09-27-09
09-24-19 05:01 AM - Post#2776316
    In response to ragtp66
tried them...way too thick won't fit in the casting.
LAWYER2
LAWYER2
Reg: 06-28-20
07-07-20 12:32 PM - Post#2798155
Any pics or a pic of the water bottle top you used? My visors are sagging bad in my convertible and make it hard to even drive.
stevelegel
stevelegel
Loc: Detroit MI
Reg: 09-27-09
07-13-20 09:27 PM - Post#2798642
    In response to LAWYER2
Sorry, it was just a water bottle. the top was not screw off style, but it popped off. You can try different things...maybe even cut a section of a thin water bottle and wrap it around the stem as a bushing.
larrybrowningmauldin
Loc: New Braunfels,TX
Reg: 08-16-05
07-24-20 06:19 AM - Post#2799390
Steve, I have several thin plastic pipette tubes that may work as insert sleeves for you. I will send one free of charge/shipping to you if you email your address to lbmauldin@satx.rr.com
cahartley
Loc: Central Wisconsin
Reg: 01-16-14
07-24-20 11:26 PM - Post#2799467
    In response to larrybrowningmauldin
I ordered bushings as well.......money down the drain.
I tried spreading open the hinge as much as I dared and they STILL wouldn't slide in.
I suggest trying a length of a plastic sipping straw which is going to be my next move.
www.youtube.com/cahartley7
Execution time: 0.175 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:51 PM
