Username Post: Which stock size tires?        (Topic#358154)
kangaroo
Reg: 11-04-06
09-22-19 12:43 PM - Post#2776155
I have been searching for about two hours and not seeing what I need so I thought Id ask. Currently I am using BFG all terrains but looking to go to a more street tire. I have a 84 c10 350/350, with stock rims. Truck is not lowered and stock height. The STOCK white wall tires seem very very small for the truck IMO. I am looking for something as wide for max traction and taller than the STOCK little white walls. I will be using the truck with the occasional off road trek. Thanks for any help or links.
09-22-19 01:32 PM - Post#2776163
    In response to kangaroo
275/60R15 is probably the most popular upgrade to an 8" wide wheel. For 3.73 to 4.11 gears, it's the perfect power band size size. Other axle ratios vary in size. A 255-275 mm in width will do better than stock.
kangaroo
Reg: 11-04-06
09-22-19 07:08 PM - Post#2776191
thanks for the help . ill look into those there . they seem to be 3" shorter than what I have now. Currently I am using 31X10.5X15
09-23-19 04:11 AM - Post#2776207
Oh, 4X4? Huge difference!! 31-33" tires are popular. 30" for street 4X4 use. Check over at www.ck5.com. They have a chart size for tires that fit without trimming or minor trimming.
kangaroo
Reg: 11-04-06
09-23-19 09:17 AM - Post#2776242
No its a 2wd. I had the larger tires on it because I was hitting different construction sites daily. No longer doing that and want to make the truck more street comfort.
09-23-19 10:39 AM - Post#2776250
What your axle ratio? Without overdrive, sticking to 29"- 30" tires would be my preference.
Mad Professor
Reg: 12-30-08
09-26-19 04:41 PM - Post#2776532
GM made 16" steel rims for the 2wd C10.
Hard to find. I got mine off a junker electric Co. truck. Not sure how wide you can go with those rims, but will be taller even with a lower profile tire. Don't forget a 5th rim for your spare.
62 Willys wagon
67 CJ5 Buick V6 w/OD
89 S10 baja package
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
11-25-19 06:18 PM - Post#2780952
    In response to Mad Professor
There should be a tag in your glove box w/the build codes.
If I was guessing....235/75-15, just like on my '86 Sub.
Execution time: 0.113 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:12 AM
