Username Post: LT-1 doesn't always start        (Topic#358150)
corvesy
corvesy
Reg: 08-07-08
09-22-19 08:10 AM - Post#2776123
I have a 94 LT-1 that will not start if its extremely hot outside or the car has run and gets up to operating temp. I suspect its the optispark as I have replaced the distributor twice (parts store optispark). Before I replace the optispark again does anyone have a suggestion as to what the problem maybe? The car will start sometimes in the morning after the temp has cooled off.
09-22-19 12:00 PM - Post#2776149
    In response to corvesy
You might try the performance forum if you don't get a response here.
chevkarl
Reg: 10-01-13
05-04-20 11:34 PM - Post#2792799
Have you tried checking the fuel pressure?
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
07-10-20 07:53 PM - Post#2798389
    In response to chevkarl
Have you checked the ignition coil? As you know, its mounted on front of the driver's cylinder head and I understand that if the correct "grease" is not used when installing/reinstalling it will eventually bake it. I had a similar experience and it cost me two tows (one home on a Sunday afternoon in the middle of mall traffic and the other a few days later to the shop when I could not figure it out - my car is OBD I) plus the cost of the coil and labor.
Good luck.
Execution time: 0.391 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:12 PM
