Username Post: LT-1 doesn't always start        (Topic#358150)
corvesy
corvesy
Reg: 08-07-08
09-22-19 07:10 AM - Post#2776123
I have a 94 LT-1 that will not start if its extremely hot outside or the car has run and gets up to operating temp. I suspect its the optispark as I have replaced the distributor twice (parts store optispark). Before I replace the optispark again does anyone have a suggestion as to what the problem maybe? The car will start sometimes in the morning after the temp has cooled off.
09-22-19 11:00 AM - Post#2776149
    In response to corvesy
You might try the performance forum if you don't get a response here.
Execution time: 0.085 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:35 PM
