Username Post: '56 sits lower that what I want...        (Topic#358149)
Brian D from NJ
Brian D from NJ
Loc: Riverside, New Jersey
Reg: 04-28-04
09-22-19 06:07 AM - Post#2776120
I want to lift my '56. I don't like the way it looks now. The springs are all original. I've done some research and have got more questions than answers.
I'm looking for a 1 to 2 inch lift all around. Stupid question, but will new springs be necessary?
Thank You
Just because your car/truck was "Made In America" doesn't mean it's American made... think about it. Buy American First.
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
09-22-19 08:50 AM - Post#2776128
    In response to Brian D from NJ
Brian do you know where are compared to stock?
How is your ride now?
Brian D from NJ
Brian D from NJ
Reg: 04-28-04
09-22-19 09:28 AM - Post#2776133
    In response to Mel Foye
Not really sure of the exact measurements as I do not have a '56 to compare to. Haven't really looked at any "56's at car shows to tell you the truth. And probably they are not a good yardstick to go by either.
But I can tell you the top of the front fenders sit well over the top of the tires. Sometimes leading to tire rub when turning. I do not have oversize wheels on this car. The car sits level, so the rear is about the same.
09-22-19 10:27 AM - Post#2776145
The stock height measurements are in the assembly manual. Link to stock height.
LtFrankDrebin
LtFrankDrebin
Loc: Coopersburg, PA
Reg: 01-25-01
10-02-19 06:39 PM - Post#2776948
And what is so wrong with a low stance?
'56 210 Townsman wagon 6cyl/3spd OD | '58 Impala Sierra Gold 348
Brian D from NJ
Brian D from NJ
Reg: 04-28-04
10-14-19 10:01 AM - Post#2777868
    In response to LtFrankDrebin
Oh, there is nothing wrong with a low stance. But my car sits so low when I have to make a sharp turn in either direction, the tops of the tires (if there is a top when turning) scrape the inner fenders. And before anyone says I have oversize tires on it, I don't. They are 15's.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
10-16-19 05:09 PM - Post#2778061
How long have you had your 56? Could the PO have installed lowering springs or drop spindles?
If so, you’ll probably have to replace those with original type equipment.
If it is just weak original springs you’ll probably have to replace the springs.
Some people used to install spring spacers that screwed in between coils to raise the car but those had a lot of issues; made for a rough ride, moved around to be uneven, etc.
Execution time: 0.091 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:22 PM
