Username Post: Power Brake Options        (Topic#358138)
kck71
Reg: 10-23-08
09-21-19 05:58 AM - Post#2776037
For a car with V-8, Powerglide, and factory power steering, what are my options for installing power brakes? I see the new master cylinder and booster units will not fit with the power steering pump on the generator, which will be used.
I'd like to stay as original as possible, which is why I posted on this forum and not the other tri-five forum here. How common was factory-installed power brakes in 57?
I was surprised to be able to find good used power steering parts without too much trouble, wondering if it would be a similar experience for power brakes.
Edited by kck71 on 09-21-19 05:58 AM. Reason for edit: No reason given.
09-21-19 02:54 PM - Post#2776069
    In response to kck71
There are offset brackets to accomodate moving the gen, to clear everything.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
09-29-19 08:49 AM - Post#2776693
In 1957 power brakes were not real common, I would say found on 5% of the cars. Power steering on perhaps 15%.
A good number of 1957 cars were still basic 3 speed 6 cylinder or 283 2 barrel basic cars.
55Nomad57
Loc: near KC, Missouri
Reg: 10-28-06
12-29-19 04:07 PM - Post#2783149
In 57 there were 2 power brake systems. With an auto trans the treadle vac power brake system was used and it would clear the steering pump. With a manual trans a remote booster was utilized with the standard master cylinder and it mounted near the hood hinge. If you can find a stock remote booster, it could be added to the stock drum brake system. My 57 had the treadle vac system which has a different pedal & linkage arrangement which offsets the system toward the driver side. I switched out the treadle vac booster system for a 7" booster, but had to modify the firewall mounting plate slightly to mount it when I switched to front discs. I had already changed out the stock gen/pump to an alternator and relocated the pump with a bracket kit so it fits low near the left motor mount.
Edited by 55Nomad57 on 12-29-19 04:12 PM. Reason for edit: No reason given.
Execution time: 0.124 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:27 PM
