Username Post: Wheel hop        (Topic#358137)
Serafin
Reg: 07-29-13
09-21-19 05:11 AM - Post#2776035
Installed a set of Ecklers traction bars on 55 Chevy, 5-speed with 3:73 posi rear. Still getting wheel hop.Installed as per directions , what am i missing.Should the bars be adjusted to the front or to the rear. Thanks
09-21-19 01:07 PM - Post#2776061
    In response to Serafin
They should be adjusted on the ground with the car at loaded ride height, I would adjust them evenly front and rear just enough to slightly preload the bar. Instructions with kit should be followed.
09-22-19 10:29 AM - Post#2776135
got pics?
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
10-09-19 04:27 PM - Post#2777493
IF these traction bars are Eckler's so-called "slapper-bars", I'd remove them, take them to a scrap metal dealer, and be done with it. There are far better slapper-bars out there, and many of the "Traction-Master" type bars. Personally, for a street car, I'd probably go with the "Traction-Master" type bars; if it were a Street/Bracket Car, I'd go with a good slapper bar. 4-links/coil overs are too expensive for me considering my car hardly gets driven these days. If you go with slapper type bars, just be sure the contacting point on the spring is just under the front spring eye, otherwise, they WILL bend your leaf springs. Ladder bars are too binding, in most cases, for the street. The other issue is having good leaf springs and shocks to begin with. I am Butch/56sedandelivery.
Edited by 56sedandelivery on 10-09-19 04:30 PM. Reason for edit: No reason given.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
10-10-19 09:00 AM - Post#2777551
I have Cal-Tracs on both of my cars and really like them.
Joer5000
Joer5000
Loc: Arizona
Reg: 07-22-13
04-23-20 10:00 PM - Post#2791933
    In response to 5Larry7
Go with the CalTracs setup they work great
04-24-20 05:55 AM - Post#2791951
    In response to Joer5000
Seconded.
HYPR
"17h Year" Platinum Supporting Member
HYPR
Loc: Shaking and Burning!
Reg: 07-19-01
05-24-20 03:52 PM - Post#2794682
I've had a set of Earle Williams bars on my '56 for more years than I can remember running everything from a mildly modified 383 to the current 719HP Supercharged Stroker. http://www.williamsclassic.com/#!__products/vstc5=...
Bob
Execution time: 0.138 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:22 PM
