Username Post: Adding AC Vents to a non Air conditioning Car        (Topic#358121)
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
09-20-19 05:30 AM - Post#2775947
Looking to add AC to my 66 impala SS sport coupe.
My interior....
I have an Automatic with Center console and center gauges. Looks like I at least need to lower part of the dash that hold the vents, the vents (center and side) and some type of AC unit.
Looking at:
Classic Auto Air Complete Perfect Fit Air Conditioning System 1965-1966 Chevy Impala
Part Number: 196-20-231-5 ($1400)
Will need:
Side vents:
Center vent:
Not my car I have an auto.. but you get the idea.
Center vent holder...
May need to have this 3D printed.....
Lower Metal AC dash:
Ted
Edited by brickwhite on 09-20-19 05:37 AM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
09-20-19 05:55 AM - Post#2775949
    In response to brickwhite
To make everything work together you will also need the AC padded lower dash pads which are hard to come by.
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
09-20-19 05:58 AM - Post#2775950
    In response to aghaga
Think I can make the non-padded one work?
Just weld in some metal over the ash tray holes?
Ted
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
09-20-19 07:53 AM - Post#2775959
The gauge package trim is contoured to fit the padded lower dash. When I installed the Classic Air on my non-factory air 66 I was fortunate enough to have a set of the AC lower dash pads to use as locators to cut openings for OEM outside ducts. I mounted center vents on the side of the gauge cluster.
Attachment: DSC00285.JPG (2.87 MB) 4 View(s)
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
09-20-19 08:19 AM - Post#2775961
That's an Idea instead of the Center vent. I have the lower dash pads on mine now and I could cut for the outside vents. .
Are you happy with the AC system? and integration?
Any pics of the side vents?
Ted
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
09-20-19 08:44 AM - Post#2775964
Attachment: DSC00347.JPG (1.4 MB) 10 View(s)
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
09-20-19 08:45 AM - Post#2775965
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
09-20-19 08:54 AM - Post#2775966
Whoops pasted duplicated message. The kit was a clean install and cools very well.I don't know about altering your pads to accommodate the outer vents. The vents bisect the pad leaving the outer piece separate. An option would be to mount the center vents as I did on the gauge package and mount the end ones under the dash until you find the padded AC lower dash pads. Installing the factory end vents is a little tricky cutting out with the curves and angles of the dash panel.
fsc66
Loc:
Reg: 05-05-12
09-20-19 11:43 PM - Post#2776026
Not sure if you have a donor car. You also need the passenger side kick panel and A/C components that mount in it. Don’t forget about wiring also. I cut my lower dash along with the center panel but if you have a donor car you can cut out the lower dash and attach on yours, much cleaner install. Clutch fan is also part of the A/C package along with all firewall components, of course hoses, compressor, condenser, etc. All shown in the assembly manual.
Paul
Execution time: 0.158 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:58 AM
