Username Post: Combustion chamber size?        (Topic#358116)
Beltfed
Reg: 10-04-18
09-19-19 02:36 PM - Post#2775909
Does anyone happen to know the combustion chamber size for heads on a 1957, #3731539.
Spec sheet from back of Danchuk catalog says v8, Dual 4BC, Fuel Injection. That can not be correct. Found car with 2bbl on it, have changed to correct for year 4bbl intake with Carter WCFB.
Hoping for 58cc.
warpwr
warpwr
Loc: Santa Clara, CA
Reg: 04-11-06
09-19-19 10:03 PM - Post#2775936
    In response to Beltfed
3731539 1957 283 283 HP FI
are the numbers I found. But I don't know the cc.
Vaughn
56 Delray 327, 5 spd
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
09-20-19 04:05 AM - Post#2775941
According to a some online charts, I see them at 60cc. Any ability to measure them?
Beltfed
Reg: 10-04-18
09-20-19 11:50 AM - Post#2775976
    In response to scrambldcj8
Can’t measure chamber. My home shop is not that well equipped. I have looked around and found a lot of different opinions, both good and bad, about these heads. Planning to rebuild engine if necessary. If so, I’m going add a few more horses with upgraded internals. Not going to go crazy as I understand that radiator is a weak link.
60 cc’s it is until told or proven otherwise.
Mel Foye
Mel Foye
Reg: 09-29-00
09-20-19 02:19 PM - Post#2775990
What one would find on a Chevy after 6x years is up in the air.
Speedway Motors has a cc checker for $25.
A stock cooling system in good shape should be fine for a mild 283. I would add an aftermarket shroud and have the blades 1/2 in and 1/2 out.
Unless you are winding 5,000 or more a LOT of times I would stay with stock style set up. For fun I can see duals and glass packs.
Beltfed
Reg: 10-04-18
09-20-19 03:20 PM - Post#2775997
    In response to Mel Foye
Popped the valve covers off and read the numbers, so that what this motor has.
Radiator is correct date code. I saved the upper and lower tanks and had the best core the shop could buy put with the tanks.
My upgrade idea is the Speed-pro Hypereutectic cast flat tops in whatever rebore is necessary. A Comp Cam 286H has been suggested for a little lope. Around a 9.5 compression ratio so pump gas still ok. Don’t believe that’s going to lite the tires very often and radiator should handle it.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
10-17-19 12:05 PM - Post#2778127
IF the heads are off the engine, then use an old CD (with the hole in the center), and seal it to the heads surface with Vaseline. Then use a large syringe/turkey baster/whatever, to fill the combustion chamber with 99% Isopropyl alcohol (reason is, it evaporates rather quickly when you're done). Fill the syringe up, squirt it through the hole, with the head lying combustion chamber "up", as flat as possible, and record how much it takes to fill the chamber up. Not rocket science, but not just a SWAG (scientific wise censored guess) either. Head may have been milled at some point, larger valves installed, or some port/polish work done, so the stock figures may not apply. Smallest chambers were the 1956 #5306 at 55.6685 CC's, until the #601, 305 heads arrived on the scene with 53.0 cc chambers. DART had 49 cc chamber heads at one time; they may still have them. I am Butch/56sedandelivery.
Execution time: 0.259 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:10 AM
