68Cam
Loc: Des Moines, IA
Reg: 05-29-04
09-17-19 04:02 PM - Post#2775751
Has anyone converted from manual drum brakes to power disc brakes on a 72 Chevelle? My horn relay is also a 12 volt power distribution point & is located where the booster fits for power brakes. It doesn't look like there is enough wire length to move it very far. I have found that a 70 Malibu with p/b has its relay on the radiator support left side, but haven't found a 72. Having it there, sounds like a very different wire loom: I'm trying to keep things looking stock. When I look up the part, I find some diff looking relays, but no distinction is made for manual vs power brakes?
Thanks for any help.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
09-18-19 01:24 AM - Post#2775773
In response to 68Cam
The horn relay is located on the radiator core support on the passenger side, on the back side, inside engine compartment.
68Cam
Loc: Des Moines, IA
Reg: 05-29-04
09-18-19 06:53 AM - Post#2775792
In response to 55MAS
Thanks for your reply. That complicates the conversion.
55MAS
Reg: 12-19-01
09-18-19 05:19 PM - Post#2775845
What kind of wiring harness is it, GM, aftermarket? Photos? Could you replace some wires with longer ones and solve your problem?
johnhem
Loc: Winona, Tx,
Reg: 06-30-01
09-20-19 09:02 AM - Post#2775967
The horn relay on a 72 is on the firewall above the brake booster. Earlier Chevelles were on the core support. 72 was only year on firewall.
John H
72 Chevelle-454-4speed
Soon to be 502-5speed
http://www.502malibu.com
2014 GMC Sierra SLT Double Cab
Give Free Food To Rescued Animals Daily
HERE |
Edited by johnhem on 09-20-19 09:03 AM. Reason for edit: No reason given.
55MAS
Reg: 12-19-01
09-22-19 06:28 AM - Post#2776121
In response to johnhem
Thanks for the correction. Things go best when more folks participate. Can you provide OP with some guidance to resolve his issue? Thanks.
johnhem
Loc: Winona, Tx,
Reg: 06-30-01
09-22-19 07:14 AM - Post#2776124
The last I heard, they do not make an exact replacement relay for 72. The Chevelle parts places have one that's supposed to work. I never tried it, so I don't know.I would think the wire harness would be for a stock 72.
John H
HERE |
