Username Post: Location of horn relay 72 Chevelle Power Brakes?        (Topic#358093)
68Cam
Loc: Des Moines, IA
Reg: 05-29-04
09-17-19 05:02 PM - Post#2775751
Has anyone converted from manual drum brakes to power disc brakes on a 72 Chevelle? My horn relay is also a 12 volt power distribution point & is located where the booster fits for power brakes. It doesn't look like there is enough wire length to move it very far. I have found that a 70 Malibu with p/b has its relay on the radiator support left side, but haven't found a 72. Having it there, sounds like a very different wire loom: I'm trying to keep things looking stock. When I look up the part, I find some diff looking relays, but no distinction is made for manual vs power brakes?
Thanks for any help.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
09-18-19 02:24 AM - Post#2775773
    In response to 68Cam
The horn relay is located on the radiator core support on the passenger side, on the back side, inside engine compartment.
68Cam
Loc: Des Moines, IA
Reg: 05-29-04
09-18-19 07:53 AM - Post#2775792
    In response to 55MAS
Thanks for your reply. That complicates the conversion.
55MAS
Reg: 12-19-01
09-18-19 06:19 PM - Post#2775845
What kind of wiring harness is it, GM, aftermarket? Photos? Could you replace some wires with longer ones and solve your problem?
johnhem
johnhem
Loc: Winona, Tx,
Reg: 06-30-01
09-20-19 10:02 AM - Post#2775967
The horn relay on a 72 is on the firewall above the brake booster. Earlier Chevelles were on the core support. 72 was only year on firewall.
John H
72 Chevelle-454-4speed
Soon to be 502-5speed
http://www.502malibu.com
2014 GMC Sierra SLT Double Cab
Give Free Food To Rescued Animals Daily
HERE
Edited by johnhem on 09-20-19 10:03 AM. Reason for edit: No reason given.
55MAS
Reg: 12-19-01
09-22-19 07:28 AM - Post#2776121
    In response to johnhem
Thanks for the correction. Things go best when more folks participate. Can you provide OP with some guidance to resolve his issue? Thanks.
johnhem
johnhem
Loc: Winona, Tx,
Reg: 06-30-01
09-22-19 08:14 AM - Post#2776124
The last I heard, they do not make an exact replacement relay for 72. The Chevelle parts places have one that's supposed to work. I never tried it, so I don't know.I would think the wire harness would be for a stock 72.
John H
HERE
Execution time: 0.132 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:55 AM
