Username Post: 1956 Chevy 3200        (Topic#358088)
jjc121
Loc: Missouri
Reg: 09-17-19
09-17-19 11:12 AM - Post#2775714
I am new to classic cars and just purchased my first, a 1956 Chevy 3200. It has a beautiful patina which I plan to continue to enjoy. It has a 265 V8 that runs good and three speed on the floor. The steering is a little loose but it's very drivable. What do I do first? Change fluids? Do I use modern fluids? Change plugs, wires and cap? Where do I get these things?
Lost but in love with this truck!
Don57
Don57
Loc: Illinois
Reg: 04-28-00
09-17-19 03:12 PM - Post#2775741
    In response to jjc121
Congratulations on the new truck and welcome to the forum!
Just a few suggestions. If the engine is running well, don't worry too much about a tune-up yet. Your priority should be making the truck safe to drive.
First do a thorough visual inspection of the wiring under the dashboard and under the hood. If the truck has it's original wiring, there's a good chance that some of the insulation has deteriorated a bit. If you find a bad spot, either replace the wire or at least wrap it until you can do a more permanent fix.
Then take a look at the brakes and brake lines for damage, rust or leaks. If the braking system is the original type, it has a single master cylinder under the driver's floor. That master cylinder has a single outlet that branches off to all 4 wheels. So if anything fails, like a line or wheel cylinder, you lose ALL of your braking except the handbrake. Not good. Sometime in the future you may consider replacing that M/C with a dual unit.
The play in your steering could be from a few places. Get under there and have someone rock the steering wheel left and right just a little. Watch the connections on anything that moves. There could be play in the drag link or tie rod ends. Replacement parts are available. The steering box may have some play and it's adjustable to a point. Read up on this before making any adjustment. Two other things to check are the kingpins and front wheel bearings.
Check those things and let us know what you find.
Again, welcome aboard!!
1957 3200 Stepside
jjc121
Loc: Missouri
Reg: 09-17-19
09-17-19 05:20 PM - Post#2775752
    In response to Don57
Thank you very much!
Mick53
Mick53
Loc: Northern Indiana
Reg: 04-02-16
09-18-19 09:26 PM - Post#2775861
Well said. Don't forget to check the rear end grease. Welcome to the club.
jjc121
Loc: Missouri
Reg: 09-17-19
09-20-19 04:35 PM - Post#2776001
It runs great. All the wiring needs to be replaced for sure and will be my first task. It has good tires, a new battery, new starter, new belt, new rear shocks, and new windshield. The headlights, high beams and brake lights work. No tail lights or turn signals. I assume the lighting issues will be resolved while replacing the wiring. It has no exhaust beyond the manifold on the right and has a glass pack on the left side. It is ridiculously loud now. I want it to be heard but more appropriately. If I didn't say before it has a 265 V8. They also say they cleaned out the gas tank and cleaned the carburetor, those things I can't confirm. They told me to use fuel with little or no ethanol if possible. I'll have to see if my small town has a station with a pump that has no ethanol. They have also bypassed the heater core by cutting the hoses under the hood so I assume the heater core is bad. I will need a defroster soon and as far as I can tell the blower doesn't work. The defroster has to go to the top of the list with the lights. Another odd thing is that the driver's door locks with the ignition key but the passenger's door doesn't even have a key hole to try and lock it. I know the driver's door lock and ignition aren't the most complicated of locks, but they keep the honest people out. Again, just any motor oil, and what weight, any antifreeze, transmission fluid, rear end oil? Or are there special fluids?
Edited by jjc121 on 09-22-19 02:30 PM. Reason for edit: No reason given.
craig32
Loc: PA
Reg: 08-05-07
11-09-19 05:28 AM - Post#2779824
Greetings! Be glad you have an original vehicle and not one someone 'modified'.
As for your door locks, only the driver's side came from the factory with a key lock. The doors lock from the inside by moving the handle in the opposite direction as opening it. I have a 56 also, and it had an inferior steering column in it with the ignition, turn signals and high beam on it. I replaced the column with an original, and a foot dimmer switch, and the original turn signal mechanism. One thing I did change, when I put in a dash ignition, I saw they were the same switch as the cars, so I got a tumbler set for a car that you can use without the key. I only use the key to lock the ignition, and I don't have my key ring banging off of the dash constantly.
BTW, these were originally intended as farm vehicles, so they never steered that great. I'll eventually be looking at a steering box rebuild, as mine is pretty worn.
66 Impala (in progress}
56 Stepside shortbed
55 Bel Air sedan
81 Corvette
02 Monte Carlo (bought new)
Mick53
Mick53
Reg: 04-02-16
11-11-19 05:40 PM - Post#2780005
    In response to craig32
My 53 came from the factory with a key lock on the passenger door only. You were supposed to unlock the door to let your lady friend in and she was supposed to slide over and unlock the drivers door. Plus it got her over next to you.
Execution time: 0.107 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:34 PM
