Username Post: Different steering wheel        (Topic#358068)
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
09-16-19 05:41 AM - Post#2775624
Anyone ever use a steering wheel from Con2R in their early Chevy?I was thinking of getting one for my 54 and was wondering if anybody had any positives or negatives on their steering wheels.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
09-16-19 06:36 AM - Post#2775627
    In response to hpva
I'm sure glad you posted this because I've been wondering the same thing! I was playing with the wheel builder this morning. Gorgeous wheels!
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
09-16-19 06:28 PM - Post#2775675
    In response to tommy49
Do you mean like a 1957 repro but 13"?
The splines should be the same, but double check! the 53 had a decent size "hub" behind it, its removable but the blinker mechanism is in there, not sure if the 57 is smaller or the same. Also, note that the 57 sticks out, while the 57 is flat, if that makes sense... like, for a 57 to be in the same spot as a 53, it would need a shorter column
I may do this if P/S makes me wanted a smaller wheel... that is, use a 13" 1957 repop. The above are just things to consider, I am sure the shaft and spline size are common knowledge... anyone?
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Sir X Loin
Sir X Loin
Loc: Naples, Maine
Reg: 04-26-12
09-17-19 03:38 AM - Post#2775684
    In response to drew1987
Let me throw my .02 in on this subject. GM has two different splines. Small and large. Small being Chevy and Pontiac, large being Caddy and Buick. There are no slip fit adapters as the spline difference is very small. I did put a 55 Buick wheel on my 51, but it took machining and was no small task. I work in a machine shop with some very creative friends. If you search here or the HAMB you can see how I did it. @sirxloin on IG as well.
Im not familiar with the wheel in question, but the answer should be provided in the spline information I laid out.
1957 Chevy Pickup 1998 -2012 *sold
1951 Chevy Styleline Deluxe
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
09-17-19 08:21 AM - Post#2775705
    In response to Sir X Loin
Con2R lets you build many different styles of wheels, they also sell adapters for your year car.The wheels are all 15 inch.
drew1987
drew1987
Reg: 02-23-14
09-17-19 05:44 PM - Post#2775756
    In response to hpva
WOW. Take a look at thier gallery... thye have some options in "series one" that are drop dead gorgeous for our cars
Member:
tommy49
tommy49
Reg: 09-28-12
09-18-19 06:07 AM - Post#2775781
The "horn rings" are welded on, just bling, nonfunctional.
Tommy
Member #51
09-18-19 08:16 AM - Post#2775795
My all time favorite wheel for a 53-54 steering column (which I've installed in the 51) is the 56-62 Corvette. It's a 100% bolt-on swap. Of course, the 53-55 Corvette steering wheel is also a direct fit --------------- but those are more than impossible to find ---------- and ultra pricey!
Sorry, I no longer have pictures of a Corvette steering wheel on the 51, because Photobucket has kidnapped everyone's pictures!!!!!!!
(I sure am glad this site has a method for adding pictures!)
Attachment: 100_0221_1_.jpg (82.62 KB) 3 View(s)
Execution time: 0.122 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:59 PM
