Username Post: 409 oil        (Topic#358067)
Fine09
Reg: 10-18-17
09-15-19 08:17 PM - Post#2775617
What weight oil should be used in a 409 engine and does it need to be high zinc oil.
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
09-16-19 11:25 AM - Post#2775642
    In response to Fine09
If I had your email address I could forward you the reply I got from Mobil when I asked them the same question.
davidgstarr63@gmail.com
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
09-16-19 08:27 PM - Post#2775679
It depends on how much wear is on the engine. If it's still tight, stick with 10W-30W. If it's high mileage, I'd go with 10W-40W or 20W-40W.
Verne
Fine09
Reg: 10-18-17
09-17-19 08:47 AM - Post#2775706
    In response to Verne_Frantz
Thanks Should it be a high zinc oil or use a zinc additive.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
09-17-19 11:41 AM - Post#2775722
I use zinc oil in all my push rod engines. Extra protection against engine damage from oil without zinc. The cost difference is worth it. Non zinc oil damaged the cam & lifters in my 57 Chevy 283 / 270 HP 2-4 motor.
I use Penn grade ( formally Brad Penn) zinc oil but there are other zinc oils that will work.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
Fine09
Reg: 10-18-17
09-17-19 01:14 PM - Post#2775731
    In response to pvs409
Thanks Do you use the 10w 30 or the SAE30 I read where the sae30 was designed more for the push rod flat tappet engines.
pvs409
pvs409
Reg: 01-10-05
09-17-19 03:27 PM - Post#2775743
I use 10-30 since I do drive my cars in cool weather in the spring and fall plus don’t want drag on the rotating assembly in the winter if the cars are started.
Paul
Fine09
Reg: 10-18-17
10-04-19 05:34 PM - Post#2777097
Is the penn grade 10w30 partial synthetic high performance oil the same as the penn grade 10w30 high zinc semi synthetic racing oil if not which is best to use in a street car.
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
10-20-19 06:21 AM - Post#2778296
Can't beat full synthetic multi grade. 10w-30 would do it for me, maybe 10w-40 if you're in a very warm climate during the summer months.
Hey T @!
Joe
Execution time: 0.233 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:10 PM
