Username Post: Under Dashboard Wiring Question        (Topic#358048)
belairbob50
Loc: OH where rust never sleep...
Reg: 03-17-13
09-14-19 07:13 PM - Post#2775526
There are three major items under the dash: the speedometer cluster, the light switch and the junction board. Do I pre-wire all three items and try to install them in the dash OR do I install the three items first and try to attached all the wire? What did you do?
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
09-14-19 08:06 PM - Post#2775531
    In response to belairbob50
I've had the cluster and the light switch out of my '50. I hooked up or re-hooked up the light switch from inside the car just below the dash then put it in place and secured it. I did the cluster both from the cowl access panel and from under the dash as well....kind of a combination of the two as needed. I've never unhooked everything from the junction board...just added a few items / wires to it. Again kind of from underneath and verified through the access panel. The wires in my harness are sort of trained to go to a certain place so that made things a little easier. It certainly would have been a lot easier without the front seat in the car and maybe the pedals dropped to the floor also.
1951 Fleetline Preservation
kensluys
kensluys
Loc: Bellingham, WA, USA
Reg: 04-18-01
09-15-19 12:15 AM - Post#2775543
    In response to RAM_51
I did the same as RAM51. In fact, I think I had the headlight switch out and back in a few times. I tried using the original one, but the rheostat wasn't working well. I finally bought a replacement switch and swapped the wires onto the terminals there.
I did mine before I reinstalled the interior, and as RAM51 suggested, it was MUCH easier without the front seat in!
1951 Bel Air - January build date.
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
09-15-19 12:08 PM - Post#2775576
    In response to kensluys
There Is an access panel under the hood for the speedometer, I did as much as I could NOT under the dash.
As for the rheostat, using the tail light terminal instead of the dash light terminal will Carry you through but with full brightness dash lights and no way to turn them down
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
drew1987
drew1987
Reg: 02-23-14
09-15-19 12:14 PM - Post#2775578
    In response to drew1987
Also,
Maybe it’s bad practice but at times I left enough wire to make my connections outside of the dash and then zip tied
Member:
belairbob50
Reg: 03-17-13
09-15-19 07:29 PM - Post#2775613
The biggest problem I'm having is the new harness has to be formed to fit. The thickness is difficult to shape up inside the dash. So I unbolted the speedometer cluster, the light switch and the under dash junction block and let the harness down close to the floor. I sorted out the wires so I can visualize where they will end up and started to shape the harness. Now I will have to wait a couple of days. I scratched the speedometer bezel going in or out. The first coat is drying and tomorrow, hopefully, the second coat will go on. Seams like I'm always backing up instead of going forward.
[image]https://[/image]
Execution time: 0.097 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:55 AM
