Username Post: turn signals inoperative '49 Chev 6 volt        (Topic#358031)
matt49
Reg: 05-26-05
09-12-19 06:57 PM - Post#2775420
Years ago I added a "Chinese" turn signal kit to my '49 Chev, stock 6 volt. Here's the scenario:
Tail lights work
Park lights work (all 4)
Brake lights work
NO turn signals as of yesterday. If flasher was bad (I've tried two of them) wouldn't the park lights just burn solid when turn signal lever is activated?
Fuse is OK.
Thoughts? Try another flasher?
Thanks in advance!
Matt
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
09-12-19 08:08 PM - Post#2775428
    In response to matt49
Have you checked to see if you are getting power to the unit. Even if the fuse is good, it could be a bad connection. Good luck with it.
Johnnie
1950 styleline deluxe sports coupe, 350 cid, TH 400, nova rear end. Gen IV Vintage air. SOLD!
1953 210 4 Door, 235 with Powerglide. All original except for the 1954 hood bird.
John 3:16
Execution time: 0.241 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:31 AM
