Username Post: GPS Speedometer        (Topic#358019)
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-11-19 04:12 AM - Post#2775316
Has anyone used one? If they work well, it would be a great improvement over mechanical speedometers and even electric...no worries about gears, cables, rear end ratios, tire sizes, transmissions, etc. The big question is, do they work well? I know my Garmin GPS can not always immediately find a satellite. Does that happen on GPS speedometers too? Any comments?
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, EZ Wire, Vintage Air, Ididit column, Cruise/Tilt, PS, 59 Corvette Steering Wheel, 4-Wheel Discs, Posies Rear Springs, Coker Radials, Nova 10-bolt, Mustang II, NCA Continental Kit.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
09-11-19 06:29 AM - Post#2775325
Cannot answer your last question but as to the use yes, a club member uses his all the time and finds it more than satisfactory.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
09-11-19 07:07 AM - Post#2775330
I had an app on my iPhone that was a speedometer. It worked well , proved my 51 speedometer was 5 mph fast. I.e. 50 on speedo was 45 . Verified accuracy against my 2016 GMC. .. I removed because iPhone would not update app due to my older phone., just didn't reload after phone upgrade
Bill
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
09-11-19 08:38 AM - Post#2775333
Used a app on my phone also, worked great but really uses up the battery on the phone. My car is still 6 volts so no phone charger, quit using it.
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
19Chevy50
19Chevy50
Loc: Wichita, KS
Reg: 06-21-19
09-11-19 09:29 AM - Post#2775338
    In response to 2D51STYDLX
I also use a GPS speedometer/odometer app on my phone from Google Play and it does not seem to use too much battery power. My mechanical speedo works when it wants to and the cost to rebuild is more than buying a new GPS speedometer. If you find one that works well please share as I will be doing something in the near future. Thanks
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
09-11-19 09:37 PM - Post#2775373
I have 3 different radar detectors in our 3 cars and they all have a current speed display which works very well.
It's always nice to know where our brothers in law enforcement are!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-12-19 03:00 AM - Post#2775377
Phone and navigation apps aside, I am referring to an in-dash GPS speedometer. I've seen them for boats and motorcycles and now for cars. Speedway motors sells a module which can make most any electric in-dash speedometer a GPS speedometer. I was wondering if any of you have tried this. I have an electric Dolphin speedometer which works pretty well but at some point in the future I would like to update it to a GPS speedometer and eliminate the pulse generator and wiring to the transmission.
Vern
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-14-19 04:50 AM - Post#2775493
Sooo, nobody has tried an in-dash GPS speedometer? Guess I can be the first but will have to wait until my pulse generator craps out.
Vern
09-14-19 05:04 AM - Post#2775494
I've driven with a gps to check the accuracy of a Classic Instruments electronic speedo. Here in the mountains there were some drop outs in reception.
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
09-15-19 05:34 AM - Post#2775550
A couple of my local friends have them. They do work well, their effectiveness is equal with satellite radio and gps as they work the same way. The only thing that’s unappealing to me personally is the black plastic square that needs to be in plain sight.
There are apps on the phone, and all of them rely on the phone’s internal gps which, if in good repair, is incredibly accurate.
Thirdly, there are gear ratio changing gizmos you can buy to change your speedometer with a standard gm cable. Mine is 9% fast. A 10% reducer world fix that. It wouldn’t fix how the speed needle wobbles from 20 to 40 when I’m going 30
Attachment: 6DB4C4B8-5A9E-4F9A-97E9-71FD70EF5938.jpeg (345.65 KB) 9 View(s)
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
drew1987
drew1987
Reg: 02-23-14
09-15-19 05:47 AM - Post#2775552
    In response to drew1987
Actually, I should say all the ones I have seen had the black square maybe they make one with out but as far as I know you’re going to be seeing this on the body of the car
Attachment: 28CA1457-51C3-4506-A5BB-33E5386AC22F.jpeg (286.38 KB) 4 View(s)
Member:
2blu52
2blu52
Reg: 03-12-02
09-15-19 06:06 AM - Post#2775553
You need to pulll the cable and lube it!
THOMAS JEFFERSON
drew1987
drew1987
Reg: 02-23-14
09-15-19 11:28 AM - Post#2775571
    In response to 2blu52
I will try that!!!! It’s like a gentle sway back and forth like docked boat in waves. I normally just go a little faster than the the flow but it would be nice to have a clear measurement of how fast that is lol
Member:
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-16-19 02:53 AM - Post#2775621
Speedway's video says the module can be installed under the dash, a door panel, or under the seat.
https://video.search.yahoo.com/search/video?fr=yfp...
Vern
drew1987
drew1987
Reg: 02-23-14
09-16-19 06:25 PM - Post#2775674
OH! I wonder if my buddies know? one dude has a 32 chevy coupe and its right out on the cowl. I am weird about technology in new cars... I wouldn't be bothered by a 2016 LS 6.2 and a 6 speed auto, but I feel the need to hide my radio and pretend the sound is coming form the stock one...
Member:
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-17-19 04:32 AM - Post#2775685
If and when I convert mine I will definitely hide the module under the dash somewhere or put it on the firewall.
Vern
drew1987
drew1987
Reg: 02-23-14
09-17-19 04:52 AM - Post#2775689
Show us your install when you are done =)
Member:
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
09-18-19 02:53 AM - Post#2775776
I will do that. Right now the pulse generator is working okay so until it goes I won't be making the change.
Vern
Execution time: 0.255 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:10 PM
