Username Post: 93 Stepside Shock Absorbers        (Topic#358018)
41wildthing
41wildthing
Reg: 12-02-15
09-11-19 02:28 AM - Post#2775313
I posted about my truck about a year or so ago when one when one of my rear spring shackles broke. The problem was they were longer than the stock ones. I resolved that issue and now have another problem that I believe may be related. I also replaced all 4 shocks and since then the truck rides horribly stiff. I used Monroe shocks. I don't know the model number, but they were black and were for the truck. I want to replace them with something else to smooth out the ride. I was thinking maybe Gabriel. I meed some input on what would be the best choice. Thanks in advance....Phil
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
09-11-19 05:43 PM - Post#2775360
    In response to 41wildthing
By chance is there any weight in the bed?
I ask this because a truck will ride rather hard when empty.
Also did you lubricate the shackle bolts?
Hopefully they are not seized up. That will make it stiff as well
Old School GM fan FOREVER
41wildthing
41wildthing
Reg: 12-02-15
09-12-19 03:35 PM - Post#2775408
    In response to rockfangd
No there is no weight in the bed. The truck used to have air shocks, however they started leaking and I had them replaced. Not at the same time as the shackles. To answer your question about lubing the shackle bolts, I have no clue as some else installed them for me. But I do want to replace the shocks and would appreciate any recomendation you might have. Thanks for your input.....Phil
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
09-12-19 07:11 PM - Post#2775423
I mentioned it because the stepside trucks weigh less as well due to the fiberglass sides.
I run KYB typically.
Monroe second.
I have air shocks on my 90 and have always had good luck with them.
It is the Monroe set. Was about 90.00 for the set and I have towed, hauled, you name it. Probably 8 years old and still hold air well
Execution time: 0.072 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:27 AM
