Username Post: lubrication problems????        (Topic#358016)
vet65b
vet65b
Loc: Albuquerque, NM
Reg: 02-09-06
09-10-19 05:54 PM - Post#2775287
Guys,
I have a 327 SBC that was professionally built about 15 years ago. Motor is mildly modified 350 HP out of my 1966 Corvette. Cam is a Comp Cam roller hydraulic with less than .500 lift. Rockers are Comp roller tip. Oil pump is a Melling 55 psi, oil pressure with 10W-30 hot is 58 psi. Motor has about 25K trouble free miles on it.
Two months ago I changed oil/filter at 2K miles as usual. Oil used is a well known Pennsylvania base oil. Two weeks later I have noise and blackened rockers with carbonized oil around the pivot ball on right side of motor. With motor idling (30 psi) there is a good supply of oil to all rockers.
My first thought was a blockage in the lifter feed galley, but ALL rockers are oiling fine. Replaced rockers, lubed with break-in lube and drove about 200 miles. Same thing is happening again, black rockers on both banks this time.
What is your best idea for the cause of this? Could is be the low amount of ZDDP in the oil I am using? Any advise apricated! Thanks Bill
Bill Wilhelm
1965 Impala SS
1966 Corvette, ordered for my 23rd. birthday
YOUNG57
Loc: Tennessee
Reg: 12-06-10
09-10-19 08:15 PM - Post#2775300
    In response to vet65b
Since this occurred after you changed oil and filter you might check and change the oil filter, it could have separated and clogged one of the galleries.
But with good oil pressure the filter shouldn’t be the problem since it is before the oil pressure sensor switch or tap. But it’s worth checking.
IgnitionMan
Reg: 04-15-05
09-10-19 08:20 PM - Post#2775302
What brand oil filter, hope it IS NOT a FRAM.
Also sounds like the viscosity is too low, and possibly additives package in oil has changed for the worse.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-11-19 10:06 AM - Post#2775342
    In response to IgnitionMan
because the issue started with the oil and filter change Id strongly suggest,
that you take the effort too, verify the dip stick reads correctly,
if the oil levels low its a problem, change both the oil filter and the oil being used,
do it immediately before more damage, potentially occurs.
a WIX filter and VALVOLINE 10w 30 would be a decent choice
whats your oil temperature? it should be lower than about 210f-220f max most of the time
your rocker geometry may be restricting the volume of oil flowing over the rocker ball pivot.
Id also suggest you back off the rocker adjustment nut at idle until the rocker clicks,
then very slowly tighten the rocker adjustment nut just until the clicking stops then add only 1/4 turn of preload,
as that will maximize oil flow to the rockers
Edited by grumpyvette on 09-11-19 11:52 AM. Reason for edit: No reason given.
vet65b
vet65b
Reg: 02-09-06
09-11-19 12:01 PM - Post#2775346
    In response to grumpyvette
Guys,
Thanks for the tips, most I have already checked.
Oil filter is 1143 NAPA GOLD, it and the original cannister are good, nothing loose inside. As for oil weight, under my ownership it has always been 10W-30. Dip stick reads correct. It's a street motor with 0.002/0.0025 clearance rods/mains. I am wondering if a lack of ZDDP could cause damage to the rocker balls.
As for oil temp, I have used an IR gun on the pan after a 50 mile run in NM heat. Oil temp is 190* to 195*
Unless you guys come up with something else the current plan is to drain oil/filter, pull rockers and inspect for heat damage, re-assemble with moly-coat EP lube and fill crankcase with racing oil. If you have any other ideas I am ready to try them!Thanks! Bill
Bill Wilhelm
1965 Impala SS
IgnitionMan
Reg: 04-15-05
09-11-19 03:56 PM - Post#2775357
If you use Moly lube, change the oil and filter again fairly soon after restart. Moly molecules are large enough to plug filter element media.
65_Impala
Reg: 12-29-02
09-11-19 09:57 PM - Post#2775374
In the last thread you started you posted that the pushrod tips and springs were blackened and now you posted that the pivot ball area is blackened. Is the issue really in the pivot ball area and not anywhere else?
I could believe oil selection affects the pivot ball, but I'm doubtful it would affect the pushrod tip or valve spring.
If you're buying another rocker set then consider going to full rollers instead of the pivot ball.
Mel Foye
Mel Foye
Reg: 09-29-00
09-12-19 04:31 AM - Post#2775379
Along with checking that the push rods are clean on the inside, are they straight?
Execution time: 0.075 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:54 AM
