Username Post: correct flywheel on engine swap        (Topic#358015)
Mauller
Reg: 08-29-19
09-10-19 02:51 PM - Post#2775278
I am replacing my 383 stroker in my 55 Chevy with an LT1 out of a 1995 Impala. I am re using my Super T10 BG 4 speed, have looked at the LT1 flywheel and clutch and it will not work. Anyone do a similar swap, and which flywheel and clutch did you use
09-10-19 03:29 PM - Post#2775279
    In response to Mauller
You can use the flywheel from an 86-99 truck. It's 168 tooth, big diameter, so you may have to use the starter from the same truck, as well as a bellhousing that accepts a big flywheel.
Mauller
Reg: 08-29-19
09-13-19 03:11 PM - Post#2775473
    In response to Rick_L
Thanks, I assume it is a small block flywheel. Not sure if big block is different, but thought I should ask
09-13-19 04:34 PM - Post#2775476
No they are different. You need a flywheel for a 350 or 305 from 86 up.
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
11-23-19 03:33 AM - Post#2780806
As far as I know LT1's are external balance so make sure you use the correct one!
An interesting swap - hope you will post along the way-
It's all good. mostly
Execution time: 0.104 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:07 PM
