Username Post: Vent or wing window...        (Topic#358008)
6T5
"2nd Year Gold Supporting Member
6T5
Loc: Asheville, NC
Reg: 07-22-17
09-10-19 05:59 AM - Post#2775223
I've noticed that the left side vent window needs to be lifted into place a little to close properly. The question is, will a worn out regulator cause this problem or is there an adjustment needed and where? Thanks...
...Ed
1965 Impala SS
59fins
Member #212 "19th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
09-10-19 05:04 PM - Post#2775282
    In response to 6T5
Have you taken the door panel off?
you can see the regulator for the wing vent, run the wing vent and watch the action of the regulator vs. the wing vent, then take the window crank regulator out and see how the movement is effected.
Bill H.
67 Impala SS
65ragtop
Loc: Carmichael, CA
Reg: 04-04-03
09-10-19 05:28 PM - Post#2775285
    In response to 6T5
I think it'll be the regulator, but take a look at the Body Service Manual, section 1D pages 18-20. That gives all adjustments for the 'ventilator assembly'.
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
09-13-19 02:10 AM - Post#2775439
    In response to 59fins
I have not looked at it yet but I will. I do know I have to turn the handle a little bit more before the wing will start moving...thanks
...Ed
1965 Impala SS
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
09-13-19 02:16 AM - Post#2775440
    In response to 65ragtop
It is a lot sloppier feeling than the right side. I'm thinking you're right and I'll just replace both sides while I'm at it...thanks
...Ed
1965 Impala SS
timmyg65
timmyg65
Reg: 08-17-14
09-13-19 05:12 PM - Post#2775474
    In response to 6T5
paste image host
This may help visualize how the vent window is supported. There are 4 stakes in the vent window frame shaft that position it in the pivot bracket. This is looking at the assembly from the outer side of the door.
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
09-14-19 03:52 AM - Post#2775492
    In response to timmyg65
Thanks for the picture, as they say, worth a 1000 words. I will report my findings when I get into it next week, the parts should be here by then...
...Ed
1965 Impala SS
Execution time: 0.192 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:49 PM
