Username Post: Trunk latch not working        (Topic#357999)
usmile4
"12th Year Gold Supporting Member
usmile4
Loc: Aurora, Illinois
Reg: 08-12-05
09-09-19 12:37 PM - Post#2775163
I have the stock keyed latch on my 51. I am always fighting to get it to latch and keep it latched. I’ve tried all the adjustment that I can and after a bit it comes unlatched. It feels solidly latched and then after a few good bumps on the road, it will be unpatched when I get to where I’m going. I’ve had a helper lock me inside and it seems to catch and latch just fine.
I’m about ready to find a complete latch both the keyed lid part and the catch part to see if the replacement parts work any better than what I have.
Has anyone replaced the stock parts with something off a newer year car? I don’t want to have to cut and weld as I don’t want to ruin the paint from excessive heat.
Thanks, Bill
Bill Gommel
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
09-15-19 11:18 AM - Post#2775579
    In response to usmile4
A replacement from your year, if yours isn’t fixable, would be a better choice. If you know how to rekey a house deadbolt you’ll be able to get through rekeying the new latch. Or an old school locksmith could do it for you
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Mel Foye
Mel Foye
Reg: 09-29-00
09-15-19 01:38 PM - Post#2775587
Bill I can't picture your assembly in my mind but here goes. Do you have the latch assembly fully cleaned and lubed?
Any spring that may be too stretched or missing?
How fresh is the trunk weather strip?
Were there ever any stops or springs on the bottom lip of the trunk?
When you push down hard on the trunk lid how do the gaps look all around?
drew1987
drew1987
Reg: 02-23-14
09-15-19 03:52 PM - Post#2775602
    In response to Mel Foye
Good point about lubed. I’ve “fixed” so many hoods that don’t latch correctly just with 5w30 and wiggling. See how freely everything moves
Member:
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
09-16-19 05:04 AM - Post#2775625
I've had good luck with soaking old latches in parts cleaner and then blowing them out with compressed air. Look for old dried up grease, and get it all cleaned out. Then lightly oil the moving parts, and as mentioned look for worn parts or broken springs. I replaced my trunk latch with a newer one, but it took some fabrication and welding.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. P/W, Remote door and trunk locks, GM cruise control, A/C.
https://www.flickr.com/photos/54237519@N00/a lbums
Execution time: 0.137 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:38 AM
