Username Post: Got a new rear end now what?        (Topic#357998)
JCray520
Loc: Tucson AZ
Reg: 09-04-19
09-09-19 01:16 PM - Post#2775159
Hey guys, I got a rear axle assembly and am going to swap out the whole thing. What do I do? What don't i do? The new rear assembly has disk brakes and came from a little later model but it is the same width and the same gear ratio. I have a 95 k 1500 6 lug rear end (43:11) 3.73
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
09-09-19 05:05 PM - Post#2775185
    In response to JCray520
Sell it and get the correct rear. Disc brake started in 99.
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
09-10-19 04:59 PM - Post#2775280
    In response to junkman104
GM never offered 3.90(1):1
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
09-10-19 05:53 PM - Post#2775286
    In response to scrambldcj8
Huh?
65_Impala
Reg: 12-29-02
09-10-19 06:08 PM - Post#2775288
43:11 is 3.91:1 gear ratio.
scrambldcj8
scrambldcj8
Reg: 04-06-03
09-10-19 06:46 PM - Post#2775290
Sorry to confuse....reply was meant to OP
So, in align with your original post....DO NOT install front driveshaft....
scrambldcj8
scrambldcj8
Reg: 04-06-03
09-12-19 06:14 PM - Post#2775418
You say same ratio, so I think you meant 41:11
OK, so the new rear came from what truck "a little later model"? And was it from an SUV or P/U (and same 1/2T or other tonnage) as the spring perch spacing may have changed or be different...I forget what if any changes to spring perches might be with newer trucks. That info is important as you would like to get that corrected before sliding it under the truck, only to find out you need to torch a few things.
Another item would be E-brake cables and if they're going to need to be changed or adapted.
What U-joint does it call for compared to your truck now (95 K1500).
Is the rear complete hub to hub with brakes and flex/hard lines ready to attach to your chassis flex (drop) line? Or do the lines to be re-routed to line up? What is the condition of the brakes...pads/rotors, and etc?
JCray520
Loc: Tucson AZ
Reg: 09-04-19
09-13-19 11:47 AM - Post#2775463
Hey thanks for the response, it is a complete setup. I believe it was from a 2003 half ton pickup short bed. Shock mount points look a little more narrow but they do match up they do have disk brakes rather than drums but I ran new brake line and the e-brake cables are fine
scrambldcj8
scrambldcj8
Reg: 04-06-03
09-15-19 04:15 AM - Post#2775545
Great, now go install and report back.
One thing which may pop up, would be a mismatch with the master cyl and/or proportioning valve. Yours being disk/drum going to disk/disk. Drums used to use some form of residual valve to keep the shoes from retracting too far from the drum each time you let off the pedal. I am not sure how that applies on the newer vehicles.
I might assume you'd have to change the master and possibly the proportioning valve (AKA: combination valve). The GMT800 (non-hyd. boost 3/4T )master cylinder is a popular swap anyway into GMT400trucks, along with the HD 3/4-1T front brake calipers.
https://www.gmt400.com/threads/swap-upgrades -to-fr...
And this one:
http://www.pacificp.com/forum/viewtopic.php?t=1079...
Hell, if you have it apart you mine as well go all out and bleed once.
Execution time: 0.442 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:41 AM
