Username Post: foot/handbrake        (Topic#357997)
stoveboltshane
Reg: 09-07-17
09-09-19 12:54 PM - Post#2775158
hi guys having trouble with rear foot/handbrake on 59 belair wheels will lockup rotating forward but not backwards,although the passenger side wheel worked both ways until i removed the drum ,didnt dismantel anything put drum back on only works going foreward now , all shoes ,retaining springs and drums are new ? input much apreciated thanks.
Hobart
Hobart
Loc: Chicago, IL USA
Reg: 11-18-02
09-09-19 01:56 PM - Post#2775165
    In response to stoveboltshane
The emergency brakes on a typical rear- drum setup are only effective in stopping the car from rolling forward, not backward.
Bill
Chicago Gearheads Car Club / Lynch Mob Racing
'59 Bel Air 2dr sedan
'68 Chevy II Nova
'72 Eldorado ragtop
'80 Z28
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
09-09-19 02:49 PM - Post#2775173
    In response to Hobart
Fascinating! I never heard that before. Does Bendix vs Huck make any difference?
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
stoveboltshane
Reg: 09-07-17
09-09-19 03:21 PM - Post#2775176
nothing to worry too much about then .sorry that should have been to bill .
Edited by stoveboltshane on 09-09-19 03:25 PM. Reason for edit: No reason given.
Hobart
Hobart
Reg: 11-18-02
09-09-19 06:42 PM - Post#2775193
    In response to mahlmann
I believe the reason they don't hold very well backwards is due to the shoes being different sizes forward vs. rearward.
Bill
'68 Chevy II Nova
'72 Eldorado ragtop
'80 Z28
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
09-10-19 03:02 AM - Post#2775214
Try adjusting them a bit tighter on the main cable and on each wheel, you may be able to improve the stopping power. If you have a manual tranny, also park with the car in reverse, it holds better than any other gear.
If you don’t have a manual, I’d recommend a conversion.
Member #2194
Edited by DonSSDD on 09-10-19 03:03 AM. Reason for edit: No reason given.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-10-19 08:22 AM - Post#2775236
The sequence for adjusting the emergency/parking/manual brake is to first make sure the brakes are properly adjusted w/o any 'hold' from the manual brake. Then, adjust the manual brake to hold (in either direction it does not matter). The amount of friction holding the shoes to the drums is the same regardless of which direction the wheels are trying to turn.
Just trying to be helpful.
Pete
Execution time: 0.226 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:35 AM
