Username Post: 99 Chevy van timing        (Topic#357996)
09-09-19 11:36 AM - Post#2775154
Ok, a friend called me on a non running Vortec van. They believed it was a fuel pressure problem. I check it. It primes to 60 PSI and stays above 55 with ignition off. So I rule that out. I pour a little fuel down the TB and crank it. Quick back fire indicated bad timing. The ignition module is being checked. While removing the ignition module, I notice the distributor is loose. It turned all over the place. The ignition module will probably test good.
Will setting the distributor to DTC and crank mark to 0 be enough? I've done distributor swaps before but this has been cranked multiple times.
'08 GMC Acadia 3.6L SLE
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
09-09-19 01:22 PM - Post#2775160
You may have better luck with the '88 to '98 forum, because the Vortec engines in the '99 trucks are LSx variants and do not have a distributor. That said, adjusting the distributor may fix the no start condition. However, I'm not sure there's a mark on that engine that will be easy to see. Also, as I recall, you have to have a diagnostics computer (like a Tech II) to put the vortec engine in a mode to adjust the timing and reset the code. The computer does monitor the timing in relation to the cam sensor and adjusts it accordingly.
09-09-19 02:30 PM - Post#2775170
    In response to jktucker92
Oh, yea cross over year for vans.
I was thinking about just turning the distributor until it starts. However I don't know how bad it would run, so setting it back to 0 is good.
Execution time: 0.397 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:33 PM
