Username Post: either. Help no start 1961 chevy impala        (Topic#357980)
Mike ortega
Reg: 05-20-15
09-08-19 06:58 PM - Post#2775091
Hello need help have a 1961 chevy impala shut car off now wont start hit starter with screw driver started up so I figured starter was bad replaced it same thing all lights work can you guys help me out also put car in neutral and no start eithier.
Bubpletop62
Loc: Bakersfield, CA
Reg: 03-21-06
09-08-19 07:20 PM - Post#2775093
    In response to Mike ortega
You say won’t start. Click, click, click? Turn key to start and NOTHING? Will the starter turn motor over? Almost sounds starter solenoid. More info. please.
Dennis Bubp
'62 Belair Sports Coupe
drbubp@hotmail.com
Edited by Bubpletop62 on 09-08-19 07:23 PM. Reason for edit: No reason given.
junky
Loc: Northeast CT
Reg: 06-27-10
09-08-19 08:18 PM - Post#2775103
try moving the gear shift lever around (automatic)and see if the neutral safety switch is the culprit. My car wouldn't start in park, but would start in reverse and drive. Had to adjust the neutral safety switch to remedy the problem. Now it starts in park and neutral, but not in reverse or drive, as the General intended.
58Yeoman
Loc: Burlington, Ontario
Reg: 12-22-15
09-09-19 04:53 AM - Post#2775114
Did car start properly before this problem? If so, did you make any changes immediately before problem started?
1958 Chevrolet wagon (Yeoman)
1961 Impala convertible
1964 Impala Sport Sedan (parts car)
1958 Biscayne 4dr Sedan (parts car)
ragtp66
Reg: 12-09-07
09-14-19 08:58 PM - Post#2775540
Try removing the wiring harness at the bulkhead connector see if its all corroded its very common for water to run into it causing your exact problem. Clean it the best you can and pack the connector full of grease it keeps the water out and also air to keep things from corroding.
Toys:
1987 Sea Ray Pachanga 22
Execution time: 20.123 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:33 AM
