Username Post: no lights , turn key nothing        (Topic#357970)
Bobs66IMPSS
Loc: Stafford, Va,USA
Reg: 10-08-02
09-08-19 12:53 PM - Post#2775050
Went to start car, turned the key and nothing. No slow turning, no solenoid clicking, just nothing. The battery is fully charged, no lights, no radio, etc. Checked negative ground cable connections on block and battery post, removed both and cleaned, reconnected both, still no change.
Installed new starter, no change. Any help would be appreciated !!
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
09-08-19 10:03 PM - Post#2775105
    In response to Bobs66IMPSS
The car (except the starter motor) gets its power through a common connection at the horn relay on the radiator support. You might start there. Good luck.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
66cayne
66cayne
Reg: 08-06-08
09-09-19 04:15 PM - Post#2775177
If the lights work but nothing happens when you turn the key your ignition switch is likely toast. I just went through this myself. A few good videos on You Tube will show how to remove and replace the switch.
A White Sport Coupe
A White Sport Coupe
Reg: 08-19-10
09-09-19 04:46 PM - Post#2775179
Hello,
1st check your cable continuity on both positive and negative battery cables. You've already cleaned the connections.
2nd check the Fisher Body bulkhead connectors. They're just below the brake master cylinder. Wiggle them with lights on etc.
3rd Inspect all wire harnesses for burned or melted or mouse eaten insulation. Check the fuse box.
Bob
fsc66
Loc:
Reg: 05-05-12
09-10-19 05:37 AM - Post#2775219
    In response to A White Sport Coupe
Agree with the bulk connector suggestion, common issue, ground sparks can cause melted wires or just bad connections.
Paul
Bobs66IMPSS
Reg: 10-08-02
09-10-19 08:46 AM - Post#2775245
thanks for your response and pointing me in the right direction. Traced 12.8 volts from battery through horn relay then to firewall, 12.8 volts there also. Checked fuse panel and ignition switch,0 volts. Pulled out headlight switch, pulled up and down on bulkhead connector, now have lights. Connector is hard to get to, but will remove and try to clean connections. Thankls to everyone for your replies.....Bob
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
09-10-19 10:32 AM - Post#2775257
Be very careful when removing the bulkhead connectors for cleaning, if they are old and brittle you will break the locking tabs on them. Ask me how I know......LOL. I ended up replacing both front end wiring harnesses in the end.
Steve65
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
A White Sport Coupe
A White Sport Coupe
Reg: 08-19-10
09-10-19 07:06 PM - Post#2775291
Clean the connectors and apply a light coat of conductive grease.
Bob
Execution time: 0.07 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:03 AM
