Username Post: '65 10-Bolt Rear        (Topic#357942)
62BillT
"19th Year" Silver Supporting Member
62BillT
Loc: Moneta, VA
Reg: 09-24-01
09-05-19 01:29 PM - Post#2774890
I've got a 10-Bolt Rear I'm trying to Decode. Casting Number is 3833443, Axle Code DB 0415 which tells me it's a 3.36 assembled on April 15th, but I'm a little puzzled on the Date Code. I can read the D fine (April), looks like a 5 for the Day (which co-responds to the assembly Code), but the last number, very hard to read, looks like it could be a 4. My question is, could a '65 Rear be possibly assembled as early as April of '64?
Thanks.
Member:
-National Impala Association
J260MikeN
Reg: 08-01-18
09-06-19 08:43 AM - Post#2774941
    In response to 62BillT
As you probably know, the 64 Impala used a different design axle altogether. I can't see how an April 1964 axle ends up in your car, unless they started tooling up for the 65 model way early. It's always interesting to research the history of these cars. Can you ell by the VIN if yours is a very early 65?
EDIT: Went back and re-read your post, sounds like you have an axle housing but not necessarily the car it goes with?
Edited by J260MikeN on 09-06-19 08:44 AM. Reason for edit: No reason given.
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
09-06-19 09:01 AM - Post#2774942
    In response to J260MikeN
Right, I got the Rear but not the car.
Member:
Execution time: 0.1 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:18 AM
