Username Post: 64 El Camino radiator help        (Topic#357927)
OldDad
OldDad
Loc: The Great NorthWest
Reg: 06-06-04
09-03-19 05:25 PM - Post#2774772
Who has the best replacement radiator for my 283 4 speed car, non air? A guy could go crazy looking at all the e-bay ads for radiators. Just looking for opinions, thanks as always
The S.O.B. from the factory...
71 1/2 ton, 64 Chevelle SS, 57 2dr Hardtop, 57 2dr Sedan, 57 Corvette, 52 2dr Hardtop, 52 2dr Sedan, and now a 49 Plymouth Coupe, 1930 Model "A", 1934 Ford Truck, all Chevy powered of course.
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
09-12-19 09:29 AM - Post#2775390
    In response to OldDad
Pretty sure 64 El and regular Chevelle use the same radiator.
Street, oval, towing and road course we don't overheat with either stock or after market.
On a long term vehicle I would consider going with a De Whitt's direct fit. Very likely this would be overkill.
Danchuck?
OldDad
OldDad
Reg: 06-06-04
09-12-19 08:50 PM - Post#2775434
    In response to Mel Foye
Thanks Mel for your response. Since I posted this I went ahead and ordered a KKS Motor Sports model RADS 281 radiator. It has a ribbed tank which looks more stock than most squared off Aluminum radiators you see. It bolted right on to the stock fan shroud on the El Camino, which is the same as Chevelle. I'm very happy with the almost stock appearance plus the easy bolt in. Now if it just cools I'll be even happier. May'be this will help someone else, it wasn't the cheapest but not the most expensive either. Wish me luck!
All times are (GMT -0800) Pacific. Current time is 02:31 AM
