Username Post: Resto paint job        (Topic#357919)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
09-03-19 05:37 AM - Post#2774731
Hi. Im wondering if the resto paint shops paint a car with fenders and doors on carts and the main body separate. Then assembling. My project is currently on a rotisseri with doors fenders etc loose and not sure how to proceed when paint time comes
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
09-03-19 05:37 PM - Post#2774774
    In response to 995jim
If you want a standout paint job make sure you do all blocking before paint with the body panels hung and properly adjusted. Make sure you block over panel seams. Use as long a block as possible. Once you are happy with the blocking, remove the panels and cut-in around them, jambs, etc. I would them rehang the panels and paint the car as a unit. Maybe not so important with a solid color, but almost a must with metallics.
1951 Fleetline Preservation
09-09-19 06:53 PM - Post#2775201
    In response to RAM_51
You have to have a great painter to paint panels off the car. The panels need to be in the correct orientation (as they would sit on the car) and even then if it is a metallic color, the metallic distribution can be way off because the painter is not painting from one panel to the next in a continuous motion the way they would with the car put together. Plus you greatly increase the chances of damaging a panel or paint if you assemble the pieces after they are painted.
1957 Cameo Carrier
Execution time: 0.073 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:00 AM
