Username Post: Killing alternator with a relay        (Topic#357916)
Marcus
Loc: San Diego, California
Reg: 02-19-01
09-02-19 07:10 PM - Post#2774709
I've got a two post kill switch mounted on my rear bumper and when I turn it off the car continues to run...I knew this phenomenon when I installed it. I don't really want to run the alternator wire all the way back to the switch. I experimented a little and found that when I disconnect the exciter wire on the alt after I turn the kill switch off it will stop the motor immediately. So I was wondering if I could use a regular relay that will turn on with the ignition yet turn off when I throw the cut off switch. And if so will I damage the alt in any way.
09-03-19 06:13 AM - Post#2774727
    In response to Marcus
Did you try opening the exciter circuit above idle speed? The exciter may not kill the alternator output above idle speed.
Marcus
Reg: 02-19-01
09-03-19 11:57 AM - Post#2774744
    In response to acardon
Ah...I did not...good point. Ill try it when i get home tonight. Thanks so much.
Execution time: 1.124 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:27 PM
