Username Post: acrylic enamal metallic run        (Topic#357905)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
09-01-19 05:29 PM - Post#2774638
Hi, can I polish out a run with like 1200 grit or is it not the way to go when dealing with a metallic paint?
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
995jim
995jim
Loc: Ohio
Reg: 12-17-06
12-13-19 04:29 PM - Post#2782094
    In response to 995jim
ended up sanding down the run and reshooting the piece for a satisfactory result
Mel Foye
Mel Foye
Reg: 09-29-00
12-14-19 07:52 AM - Post#2782121
That is good news.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
12-14-19 08:50 PM - Post#2782173
Didn't see your post when you posted in September. Was going to say, you can certainly make the run smooth...but I'd bet you still saw it because of the way that metal had oriented itself in the run. Was also going to say spray the panel once again and try to replicate gun settings and distance. But looks like you already got that accomplished.
1951 Fleetline Preservation
Execution time: 0.109 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:57 AM
