Username Post: sb chevy        (Topic#357884)
otis3
Reg: 04-29-14
08-30-19 07:05 PM - Post#2774522
just changed header gasket on passenger side.cranked it up,sounded go,noticed a intake leake.took intake off,put in new gaskets,now have valve noise.on an off for about 20 sec,then became constant.no miss.took intake off,cant find anything.any ideas?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-31-19 06:16 AM - Post#2774549
    In response to otis3
did you accidentally drop some trash into an intake port?
sounds like its time for a compression test
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
09-01-19 04:42 PM - Post#2774636
    In response to grumpyvette
You didn't mention if you pulled the valve covers or not.....? left something behind when putting valve covers back on?
otis3
Reg: 04-29-14
09-02-19 05:45 AM - Post#2774660
going to pull heads,anyone know cost of machine work?like,3 angle valve job,screw in studs for rocker arms?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-02-19 11:22 AM - Post#2774672
most places locally will charge in the $300-$400 range
for a 3 angle valve job and conversion to screw in rocker studs, if you don,t need valves, or valve springs replaced
obviously youll want a firm quote in writing describing what needs to be machined and replaced,
Edited by grumpyvette on 09-02-19 11:25 AM. Reason for edit: No reason given.
otis3
Reg: 04-29-14
09-02-19 04:52 PM - Post#2774692
thanks
Execution time: 0.98 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:00 PM
